Old 08-30-2014, 10:10 PM   #101
2012 Solera
Originally Posted by pinkstonj View Post
Ok I now have clearance and running light problems. I have a 2012 Solera MB24 that I am setting up a toad, and when I did my first check of the lights everything was ok. After I made up my Solera to my toad cable the running light on the Solera stopped working. So Ive been reading about this tail light harness and module circuit board panel. Does anyone know where it is located on a MB 24? And is there any fix for the DIYer?
I have not had this issue, so the following is sourced from this forum. "Use at your own risk".
Assuming the Murphy Bed version has the module in the same place as the "S", see this thread: Running lights GONE posts 25, 26 and 27. Behind a screwed-on cover above the sewer connection on a shelf.
If you are lucky, maybe you just blew a fuse on this module hooking up your Toad. Post #16 by Pedrodasdas on the "Running Lights Gone" thread shows a picture of the module and its fuses.
There are also several reports of uncrimped wires, a short from a screw through wires, flooded taillights, etc causing this failure and not involving a failed module.
If your module has failed, as to a DIY fix - I've noted three of interest:
1) lowandslow has posted a great work-around approach using the trailer connection. See posts 80, 81 and 82 earlier in this (2010 Solera, clearance and rear parking lights) thread. He has even added a trailer connection. I carry a trailer plug with me "just in case". Inconvenient - you have to unplug the connector to turn the lights off - but a GREAT emergency countermeasure.
2) peterfinurke successfully repaired the module by replacing a defective relay on the board in the module. Running Lights Gone thread linked above, post #54.
3) emilizik reports earlier in this (2010 Solera, clearance and rear parking lights) thread, post #11, that a Mercedes mechanic successfully bypassed the module with a relay.
Should my unit fail, after getting home with lowandslow's workaround, I will likely try this last approach. I believe a 12 volt relay connected with the coil wired between the "park in" wire and ground, and the contacts wired (fused) between the "brown wire" (running lights) and the 12 volt power input wire to the module should work.
Would value comments - particularly from Gyasi.
Let us know how you make out -
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 08-31-2014, 07:24 AM   #102
Thanks JLeising. I'm still looking for the module! Reading through the post before I made one, I read about some MB mechanic bypassing a SAM module mentioned in post 51, 55, 56, I was thinking maybe he bypassed a MB module (SAM) up front somewhere. Or is the module he bypassed the one in the picture in post #16 by Pedrodasdas on the "Running Lights Gone"?
pinkstonj is offline   Reply With Quote
Old 08-31-2014, 08:37 AM   #103
2012 Solera
Don't know what was bypassed. My thought is to bypass just the running light portion of the module in pedrodasdas' picture.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 08-31-2014, 10:02 AM   #104
Help
So you think the module pedrodasdas' picture is what is bypassed and is added by FR. And there is nothing to do to anything on the MB side like the (SAM module). Oh! The module in pedrodasdas' picture has turned out to be an elusive little creature. Apparently it is hid really well on the Murphy Bed model.
Old 08-31-2014, 11:22 AM   #105
2012 Solera
jamiller45 (a previous Electrical Engineer for FR "C" motorhomes) said "The connection points for most of the wiring from MB to FR is in 2 plugs mounted on the crossmember behind the spare tire." Post #36, "Running lights GONE" thread. Maybe you can follow wires from that point to find your module.
My thought is that the module is actually an array of relays. In my assumption, the coils of the relays are driven by the SAM module. People have indicated that they measure 12 volts on the running light input, but zero on the output. My suspicion is the relay has failed. Note that peterfinurke repaired the module by replacing a relay. My thought is to wire a redundant relay around the defective relay on the board. Don't want to mess with the Mercedes SAM if avoidable.
Again, mine hasn't failed - so all is conjecture!
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 09-03-2014, 07:45 PM   #106
I found it! The location of the module on the 2012 Solera 24M is behind a panel in the lower rear passenger side storage bin. There was a 10 amp fuse that had blown I replaced it with a 15 amp maybe that will handle the extra lights that I added to the toad without overloading the circuit.
ID:	62074   Click image for larger version
Old 09-03-2014, 11:19 PM   #107
2012 Solera
Great! Congratulations! Sounds like the best result - blown fuse, module okay.
JLeising
2012 Solera "S"
Calif SF Bay Area
