Old 10-26-2015, 02:48 PM   #1
Farkasb's Avatar
2401W Slide Question
Just took delivery of 2401W and noticed that the top back slide mount that bolts onto the main wall has no screws pic attached. Can anyone confirm that's correct?
Also On the outside when closed it does not meet up flush, sticks out about an inch from the side wall. Is that normal?
ThanksClick image for larger version
Name:	ImageUploadedByForest River Forums1445888866.272403.jpg
ID:	92909Click image for larger version
Name:	ImageUploadedByForest River Forums1445888888.549101.jpg
2016 Forester 2401WS
Farkasb is offline   Reply With Quote
Old 10-26-2015, 06:46 PM   #2
ThanksAttachment 92909Attachment 92910
Not sure about the inside but as long as the rubber seals are contacting the mating surface, the outside is normal - same as my 2401R.
jdyson
(former owner, went back to Class A)
(but enjoyed our brief 'experiment' in downsizing!)
'16 Forester MBS 2401R
Hellwig 7254, TireMinder A1A & Sumo Equipped
jdyson is offline   Reply With Quote
Old 10-26-2015, 07:53 PM   #3
Farkasb's Avatar
Thanks!
The dealer said both areas were normal but was looking for a second opinion. The inside just doesn't seem right.
Old 10-26-2015, 08:08 PM   #4
I have a 2401w as well and asked the same thing about the 1 inch gap at the bottom of the slide and was told that was normal. It doesn't look quite right but if it is normal it may be to counter the weight when out, results in less lean... Just a theory.
2016 Sunseeker W MBS
kysunseekermbs is offline   Reply With Quote
Old 10-26-2015, 09:01 PM   #5
Farkasb's Avatar
Hey Kysunseeker, thank you for the reply.
When you have a chance do you mind checking the back slide top brace / bracket on the inside. Mine appears to be missing screws. Have the pic posted above.
Old 10-26-2015, 09:20 PM   #6
Sandiegodoug's Avatar
I have a 2013 s and gap is a lot smaller , can't even see seals when closed.
Sandiegodoug is online now   Reply With Quote
Old 10-26-2015, 10:37 PM   #7
dukeboone's Avatar
The gap on my S is much smaller, but that may be related to the slides being different in size and technology.
2016 Forester MBS 2401S
dukeboone is offline   Reply With Quote
Old 10-26-2015, 11:38 PM   #8
Pod2Vibe's Avatar
From the pic, it sure seems that those screws should be there!
Pod2Vibe
2015 Solera MBS 24R - Hellwig/Sumo Equipped
TOAD: 2014 Fiat 500 Abarth
(Sold the Vibe 6506)
Pod2Vibe is offline   Reply With Quote
Old 10-27-2015, 10:37 AM   #9
Looks like they failed to install the screws and an adjustment is needed so it closes flush. I'd send those pic's directly to Forest River. The dealer is ALWAYS going to say "it's supposed to be that way". For the money you spent, you deserve to have it corrected.
barnbnb is offline   Reply With Quote
Old 10-27-2015, 02:18 PM   #10
GM
bclemens's Avatar
S and W are different slide mechanisms. S is a below floor slide, so requires more pressure since the bottom is the only thing really holding it all in (common).
W is a Schwintec slide and will not close as tightly. The slide motors sense resistance and will cut of when it feels it has "sealed", not keep pulling it in.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
slide
