24R with Sofa Option
I had a lot of people asking for this....finally had one coming offline.
Pedestal leg is tapered on the bottom so it fits into the mounting plate. Is ROCK SOLID, unlike those nylon skinny ones that wobble.
The top of the leg is not tapered and can be cut down if you wish (if you think the table is too high) On the table top, there is a bracket with a compression ring. That let's you tighten down the table top, which also means you can swivel it if you wanted to add some seats around or anything so the short end faces the sofa.
Both items will store on the slide floor, below the sofa.
