Old 12-28-2012, 12:34 PM   #1
Loefflerh's Avatar
A/C Blower Question
Does the blower / fan of the air condition run continuously or does it turn of after the thermostat turned off the compressor??
I had a trailer once, and even though the compressor turned on and off according to the set temp, the blower was on continuously - I hated that. Thanks for an answer!
And does somebody know what kind of valve stems a brand new 2013 Solera 24R is coming with? Metal or rubber?
Hans
Loefflerh is offline   Reply With Quote
Old 12-28-2012, 12:40 PM   #2
TURBS's Avatar
Hans
Fan should shut down when a/c pump shuts off.
Old 12-28-2012, 04:24 PM   #3
VinceU's Avatar
Hans
You need to set your blower setting on Au or Auto, not " on or Low or HIgh". It will start and stop with heat or AC operations.
VinceU is online now   Reply With Quote
Old 12-28-2012, 04:24 PM   #4
Depends if the fan on the thermostat is set to 'on' or 'auto'. On will be on all the time, Auto will make the fan run only when compressor is running.
Old 12-29-2012, 11:08 AM   #5
GM
bclemens's Avatar
New Soleras come with the Air-Flexx Extensions.
air-flexx® valve extensions
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 01-02-2013, 11:10 AM   #6
Loefflerh's Avatar
Thanks to all the answers..I put the order in for a 24R!
Hans
