Old 08-25-2013, 10:44 PM   #1
A few questions about our new 24MS
My wife (Fla Lizard) and I picked up our new 24MS yesterday from the dealer and have a few questions we think will be much more likely to be answered correctly by this forum than the dealership (not slamming them, just don't think they know).
So, in no particular order:
Is anyone else getting a "rumble strip noise" during deceleration? I noticed this every time I was slowing down through about 10mph, 1000-1500ish rpm. I assume it's some sort of transmission issue... the chassis is a 2013 Sprinter. This problem was not evident on the unit we test drove a few months ago.
Is there a chassis battery disconnect switch similar to the house battery disconnect switch? If not, generally how long are you able to let the unit sit without having the chassis battery die?
Has anyone figured out if the 2013 chassis is prewired for a tow brake controller and either way, any tips on installing a brake controller?
Is there a trick to getting a DVD to display on the main TV from the Magnadyne dash unit? The left, right and video RCA connectors are plugged into AV2 input on the back of the TV and appear to be connected correctly to the back of the Magnadyne unit, but no video on the TV, regardless of input source on the TV.
Can we get the data card for the chassis from Forest River or do we have to find a sympathetic MB dealer to print it out for us?
Has anyone added an electronic management system display panel to see what kind of electrical loads the system is experiencing... charging rates to the batteries, amperage loads from the generator, etc?
Has anyone added an additional propane port to a 24MS (to connect a gas grill) or an Extend-a-Stay?
Thanks in advance for the help... if you do well, I'll ask more questions... Brian
Fla Lizard is offline   Reply With Quote
Old 08-25-2013, 11:11 PM   #2
Sandiegodoug's Avatar
I've had mine sit for a couple of months and when I went to start, fired up on first try
Our DVD play perfectly through the main tv on av2
I always turn off coach when I park it even if for Just a week.
Sandiegodoug is offline   Reply With Quote
Old 08-25-2013, 11:17 PM   #3
I carry an extra propane tank for my grill and my 40000 btu outdoor stove
Fits perfectly in the compartment by the stairs.
I have a s model but similar
Old 08-26-2013, 07:05 AM   #4
Congrats! I'm sure you will enjoy it. See you on the road.
DebbieMH is offline   Reply With Quote
Old 08-26-2013, 08:33 AM   #5
2012 Solera 24S
I have a 2012 year model 24S so some of my answers may not be applicable to you but I can answer a couple of your questions.
There is a Mercedes chassis battery disconnect near the accelerator pedal. This is identified in the Sprinter manual.
I donít have the Magnadyne so I canít help you there.
As far as the electronic management system, I have added a Xantrex LinkPro battery monitoring system and a Progressive Industries EMS-HW30C surge protector with voltage protection. The Xantrex provides information on the status of the house battery system and the EMS protects against all kinds of problems with poor shore power as well as a readout of amperage being used.
Nats is online now   Reply With Quote
Old 08-26-2013, 11:22 AM   #6
"Is anyone else getting a "rumble strip noise" during deceleration? I noticed this every time I was slowing down through about 10mph, 1000-1500ish rpm. I assume it's some sort of transmission issue... the chassis is a 2013 Sprinter. This problem was not evident on the unit we test drove a few months ago."
No, I don't get that at all ... might want to take to a MB dealer if you have one close to you to check it out. I don't have the Magnadyne anymore, so can't help you with that either. Guess I'm not a lot of help - sorry. But again, enjoy!
Old 08-26-2013, 12:33 PM   #7
Taylorgso's Avatar
1. I have not heard the "rumble strip" noise. You may want to have MB dealer take a look at this.
2. There is a chassis battery disconnect device in the floorboard area near the top of the accelerator pedal. Should be a reference to this in your chassis owner's manual. I've located it but never tried to disconnect!!
3. I understand there is a connection for a prewired brake - read it on a forum post somewhere - you might do a search on the Solera Forum. I have no need for a brake controller, so never looked! If you're thinking of towing a car you'll need some other type brake control for the toad brakes.
4. First, insert the DVD into the Magnadyne and Make DVD active. Then, you need to set your Television input to one of the AV inputs. DVD in Magnadyne should then show up. You can use your Magnadyne remote to control it
5. Not sure about data card? What are you referring to? If it's MB build order you may have to go to an MB dealer. Nothing came with mine!
6. There are several devices on the market that monitor the electrical/battery system. The EMS from Progressive has a remote readout, but it is for monitoring AC input. Solar Power system dealers have devices that monitor Battery functions: charge rate, level, discharge rate, etc. etc. I believe some of those will also read data concerning AC input. Do a google for RV Solar Systems, Inc.
7. Extend-a-stay is available from almost any RV dealer, and they should be able to install it. Alternatively, a propane dealer can do the same!
Glad you finally got delivery of your MS (just as FR announced they are discontinuing that model! I also have the MS and would not have selected the S model (which was only other model available at the time). A shame... hope it's only temporary 'til they work out the bugs from the lift system!
Ed (N4RWU) & Becky Taylor
Mistie (Walks 4-down)
Greensboro, NC
Taylorgso is offline   Reply With Quote
Old 08-27-2013, 04:24 AM   #8
Regarding the DVD: make sure the parking brake is set. Magnadyne has a safety lockout on viewing DVD while moving, but it is actually on parking brake. If an orange wire were to become disconnected and find its way to ground the safety interlock would not work and the DVD would show all the time ;-)
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 08-27-2013, 07:57 AM   #9
GM
bclemens's Avatar
Parking brake lock out only applies to the Magnadyne screen. The TV screen is a separate output and should play no matter what. If you want the little screen to play, then the emergency brake needs to be engaged.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 09-02-2013, 07:52 PM   #10
Forest River finally replaced the radio in my 24MS as there were so many problems with it.
sjudd is offline   Reply With Quote
