Old 08-04-2016, 12:46 PM   #1
AC Problem I Guess??
With no air on and the wife running the Micro this morning all power went off. I am stuck with 30 Amp power going into my 2013 Solera "S" with my surge protector in the green from the RV park and somehow lost power into the RV. Checked circuit breakers under stove all okay. Turned on the DC power and everything works. Any ideas would be appreciated-Thanks.
CaptDan
"Happy Travels"
CaptDan is offline   Reply With Quote
Old 08-04-2016, 12:54 PM   #2
Head Rambler
Do you have a multimeter that you can check voltage with?
If the EMS is showing power from the pedestal, then it seems that the EMS isn't passing power.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 08-04-2016, 12:59 PM   #3
ilmor's Avatar
CaptDan
"Happy Travels"
Another camper had a similar issue here recently. Turned out the surge suppressor was bad. After he bypassed it all was well.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 08-04-2016, 01:42 PM   #4
[QUOTE=ilmor;1280410]Another camper had a similar issue here recently. Turned out the surge suppressor was bad. After he bypassed it all was well.
Started the Generator-Everything worked fine. Pulled my "Surge Guard" applied 30Amps shore power-Everything worked fine. It's the Dam- Surge Protector. Thanks for all the responses-Now I need to buy another! Thanks Again.
Respectfully,
CaptDan
"Happy Travels"
Old 08-04-2016, 01:54 PM   #5
ilmor's Avatar
[QUOTE=CaptDan;1280462]
Respectfully,
CaptDan
"Happy Travels"
