Old 02-01-2015, 01:55 PM   #11
Sandiegodoug's Avatar
If your next to bathroom laying down and TV swung out perpendicular to wall you can see it. We have an S
I just added the small bedroom TV-dvd , seems more convenient
Sandiegodoug is offline   Reply With Quote
Old 02-01-2015, 03:06 PM   #12
Loefflerh's Avatar
I posted that earlier but here it is again maybe it helps: Instead of having 2 TVs I bought from Amazon 2 mounts:
Amazon.com: VideoSecu LCD Monitor TV Wall Mount Articulating Arm Bracket for most 12"-24", some up to 27" with VESA 100/75mm LED Flat Panel Screen TV ML10B 1E9: Electronics
and 2 quick release brackets:
Amazon.com: Ergotron Quick Release LCD Bracket (60-589-060): Electronics
one for the living room and one for the bedroom. Those are quick disconnects - so one TV is plenty and it takes less than 30 sec to take the Tv from front to back or back to front.
The one in the living room I mounted where the ladder is stowed - low so I do not get a stiff neck when watching! It swings out easily and even in the "out" position you can get in and out of the coach. And as a side effect - I can swing it around and watch TV from the outside through the screen door.
Pictures here:Outside TV post #4
Loefflerh is offline   Reply With Quote
bed
