Old 07-30-2015, 12:14 PM   #11
I have a 2015 Coachmen Prism 24G that has the same problem with the sub-woofer.. I have turned down all the adjustments in order to stop the vibration. I believe the problem is the way it is mounted. Unless I can figure out a fix, I will probably just take it out, and use the cabinet for storage.
jeffrapp is offline   Reply With Quote
Old 07-30-2015, 12:50 PM   #12
Put both the frequency controls in the center and the volume control just barely on until you get some bass. If still to loud on the balance menu of the Jensen unit you can turn down the sub woofer even more.
SSmbs is offline   Reply With Quote
Old 07-30-2015, 12:57 PM   #13
Thanks, SSmbs.
I'm not sure which controls you are talking about. Do you mean the controls on the sub-woofer itself, or the Jenson unit, or both?
Old 07-30-2015, 01:13 PM   #14
3 knobs on the sub woofer and an additional adjustment on the Jensen in the dash. Mine came with the dash unit adjusted to center but maybe yours is adjusted high.
Old 07-30-2015, 02:13 PM   #15
Thanks!
I believe I only have 2 controls on the sub-woofer, but I'll check it out the next time I go over to the RV.
BTW, the Jensen in my unit is in the saloon, not the dash unit, so it may be a different sub-woofer.
Old 07-31-2015, 07:01 AM   #16
Wolverine 1945's Avatar
I did not even know ours had controls until I removed it !!!
It was installed so close to the corner of the compartment !!!
It is no longer a problem,,, in the basement of our house in a box !!!
Wolverine 1945 is offline   Reply With Quote
