Old 08-02-2012, 10:41 PM   #1
Unhappy AM is broken on my 2012 Solera w/ Magnadyne
First day on the road with my new toy. The AM reception is awful. 40 miles from Cheyenne Woming the AM scan never stops on a station. Thank heavens I had XM installed at the dealer before I took delivery. Any suggestions?
Don Wills is offline   Reply With Quote
Old 08-03-2012, 12:28 AM   #2
papap's Avatar
Have never even tried the AM. LOL
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 08-03-2012, 09:52 AM   #3
GM
bclemens's Avatar
I wonder if there is an AM antenna? that is not hooked up. I seem to recall a while back bad AM reception due to some antenna issue...but I can't remember if it was just AM or both. Then again I just looked at the install manual and it only shows one antenna hook up.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 09-16-2012, 08:24 PM   #4
Poor AM reception
AM reception is horrible on class Cs. I believe it may be due to the location of the antenna, under the portion of the coach that is overhanging the cab. It has a blocking effect on the AM frequency band. I've played around and if the antenna is located away from the unit, reception improves.
KQ2N is offline   Reply With Quote
Old 09-16-2012, 08:40 PM   #5
hkreck's Avatar
The antenna on the Solera is located on the roof of the rig next to the TV antenna.
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 09-16-2012, 11:06 PM   #6
2012 Solera
From previous posts, I understand Forest River recently? moved the Solera radio antenna from somewhere on the cab to its present position on the roof next to the TV antenna. Several reception complaints in this forum on units built prior to this change. Mine is on the roof - reception seems fine.
Old 09-17-2012, 10:43 AM   #7
bclemens - is that true? Is the AM antenna on the newest Soleras on top? How can I get mine moved up there?
Old 09-17-2012, 10:54 AM   #8
Coachmen Adrenaline
The whip antenna on roof of Solera's are am/fm antennas. This should be the same for ALL Solera's built that have the Magnadyne radio installed. It was actually that way with the previous radio also.
jamiller45 is offline   Reply With Quote
Old 09-17-2012, 08:47 PM   #9
We had a loose wire (not plugged into anything) under the passenger's seat. We asked the dealer what it was for and nobody knew. When we realized a few days later that our radio reception was horrible my husband figured he knew what that wire might be for. He looked around and found the female end of another cable underneath the mat between the seats. That cable apparently goes up to the antenna on the roof. He plugged the two together and presto, that fixed the radio reception. Maybe that's your problem.
marirules is offline   Reply With Quote
Old 09-18-2012, 07:19 AM   #10
Now a "Top Member"
EdJunior's Avatar
What is this "AM" that you are referring to? Oh, wait...I seem to have some recollection of it in my "wayback" space. <gigglesnort>
Boy, I haven't even listened to AM in probably 15 years. I'm not even sure how to get it on my radios. But, I would agree it's either the placement of the antenna, or it's not hokked up properly.
Ed and Sharon
2010 Wildcat 28RKBS
2011 Ford F-250 XLT, 6.7L PSD
Ride-Rite Airbags and Airlift wireless remote compressor...nice!
