Old 05-24-2015, 03:04 PM   #1
CharSolera's Avatar
Another Question - Stabilizing Jacks
First trip out for me. The stabilizing jacks are down on blocks. I put them down when I arrived and they're turned off. But, they just adjusted by themselves when a gust of wind went through. Is that what they're supposed to do? Solera 24S.
Charlene
and catpanions, Purrl & Lucy Lu
2014 Solera 24S
CharSolera is online now   Reply With Quote
Old 05-24-2015, 03:20 PM   #2
Mikegjax's Avatar
That is a new one. Don't think they should do that. Mine don't.
2014 Solera 24R
USN Retired
Mikegjax is online now   Reply With Quote
Old 05-24-2015, 04:26 PM   #3
Can I ask do you have the bigfoot stabilizing jacks or do you have a different type. My bigfoot jacks are in the rear and hang low and I really do not like them and am thinking of changing to something different like Stabi-Lite Electric Class C System (Sprinter Chassis) | Electric Jacks | Class C Motor Homes | Motorhome | Online Store | Equalizer Systems | A Days Company | Official Site.
Has anyone used these?
At present our unit is en-route to the factory for slide room repair. Must say FR seems to be trying to make things right, we will see next week.
Dave & Pat
Solera 2014 24S
1992-2012 full timing
Part time
2012-present
groupleaderpj is offline   Reply With Quote
Old 05-24-2015, 05:53 PM   #4
My Bigfoot stabilizers kept turning themselves on and extending further even though I had them down already. Had to cut a wire to the box because I was on a trip. On return I took it to my dealer and he reprogrammed it. Worked good for awhile but now on another trip it's starting to do the same thing. It turns itself on and extends. This time I'm going to put a switch in the red power wire to make sure it can't activate, as soon as we get home.
jngspencer is offline   Reply With Quote
Old 05-24-2015, 06:13 PM   #5
Mine have never powered up and extended on their own. They have moved slightly while camping, I believe one jack goes in slightly and the other goes out slightly. It is more of a pop or thud, not a jack actuation. After camping for a couple of days the RV will become out of level side to side with the driver's side getting lower. I always thought this was due to the added weight of water being added to the waste tanks.
Eric99 is offline   Reply With Quote
Old 05-24-2015, 06:20 PM   #6
Mine definitely activates. It is most surprising when in bed and instantly wakes me up. Apparently this is a common problem and has been discussed lots in the forum. Thought they had it fixed but guess not.
Old 05-24-2015, 06:59 PM   #7
FLPhotographer's Avatar
What year of manufacture are these MH?
In the end, it's not the years in your life that count. It's the life in your years. - Abraham Lincoln
FLPhotographer is offline   Reply With Quote
Old 05-24-2015, 07:52 PM   #8
CharSolera's Avatar
Scaring me! I knew this had been a problem, but I thought my model year was OK. The factory bulletin that was posted in a different thread said all units after a certain date had the programing fixed. They are Bigfoot stabilizers. It is definitely the same sound they make when I extend or retract them. This is a 2014 Solera made sometime after 10/2013. I'm not using the key fob at all. Maybe someone else in this RV park has the same frequency? It happened when there were gusty winds. I don't know if they actually extended or retracted, or if the motor just came on. Wish me well. It's a 300 mile drive tomorrow and I want no problems! Does the dealer get these kinds of problems or should I contact FR? (I had hoped never to have to work with the dealer again.)
Charlene
2014 Solera 24S
Old 05-24-2015, 08:37 PM   #9
Mine is a 2015 Solera 24R on a 2014 Mercedes chassis, purchased August 2014.
It is possible that someone else in the RV park has something that causes it and it may not be a Bigfoot. That's why I want to put an inline switch in place that will prevent that possibility. If there was a breaker for it that would suffice but I could never find one.
Old 05-25-2015, 12:16 PM   #10
Had the same problem with my 2014 Solera 24 R with Bigfoot stabilizers. Happened last year at the international rally in Elkhart. I called the mfr, Quadra Mfg, White Pigeon, MI, 269-483-9634 or 800-752-9815 and spoke with a customer rep. It was a programming issue that he helped fix over the phone. It had something to do with only responding to my remote or button. Sorry I don't recall exactly what we did but no issues since then. Hope this helps.
David100 is offline   Reply With Quote
jacks
