Old 06-24-2012, 01:46 PM   #1
hkreck's Avatar
Any idea what this is?
Does any one have an idea what this is, it's on the engine of a mercedes sprinter it has a spring load in it. I'd just like to know what it is?
ID:	15656   Click image for larger version
hkreck is offline   Reply With Quote
Old 06-24-2012, 02:41 PM   #2
2018 FR3 30DS
It's the positive side if you have to jump start your engine. If you look on the right side of the engine wall, you will se a knob (sort of) sticking out. This is the negative side for jump starting. If you push (or pull...I forget) the red knob it will reveal a rod that you connect you positive jumper cable.
I overlooked the second picture...you can see a plus symbol behind the red knob and a V12 for 12 volts
2011 Solera
Slow_movin is offline   Reply With Quote
Old 06-24-2012, 04:51 PM   #3
by the way how do you like your new solera that you waited so long for
gerrym51 is offline   Reply With Quote
Old 06-24-2012, 05:31 PM   #4
hkreck's Avatar
Okay that make since thanks for the info.
Old 06-24-2012, 05:33 PM   #5
hkreck's Avatar
Gerry I'll let you know at the end of the week heading out on the maiden voyage tomorrow. So far thou I like it.
