Old 11-20-2012, 09:35 PM   #1
Anyone install Winnebago View table in a Solera
One of the options available for a Winnebago View (very similar to the Solera) is a pedestal table for the driver and passenger seats when they are swiveled around 180 degrees.
Has anyone done this? What was the cost?
All it is is a table top, a pedestal and a plate attached to the floor. It would be a show stopper if the floor where the plate would be attached is not structurally sound for this application.
Wayne in Coarsegold near Yosemite
2013 Forest River Solera 24R
2014 Jeep Wrangler Rubicon
ATV trailer for the following toys
2008 Yamaha WR250R,2009 Honda CRF150F
2008 Polaris Scrambler 500
PopBeavers is offline   Reply With Quote
Old 11-23-2012, 01:35 PM   #2
2012 Solera
JamesR's Avatar
this is the same question i have! l assume that the floor plate would have a recess socket that goes into the floor (not the slide out). i would think that structural strength would not be an issue. checking clearance from underneath the coach would verify where it could go. of course it would be a tripping point on the floor.it would take some courage to cut a hole in the floor. any way, good luck.
JamesR is offline   Reply With Quote
Old 11-23-2012, 01:42 PM   #3
I saw a View with the plate installed. It sticks up about 1/4 to 3/8 inch. It did not recess into the floor. The plate was flush mount.
I could not tell if the bolts holding the plate were lag bolts or through bolts.
I do not know what material is below the mounting location. I wish I had crawled underneath to try determining the construction.
