Old 04-23-2013, 11:22 AM   #1
Robert Mayberry
Arctic Pac
Hi,
Its down to 25 and supposed to go down to 22 tonight where I'm currently camped while waiting for it to warm up tomorrow.
So I turned on the Arctic Pak switch.
Does anyone know what it does?
Under the fridge I can hear a whirring sound. Like a small fan. It stops when I turn off the Arctic Pac switch.
Just curious.
Thank you.
Bob
2011 Solera
San Francisco
robertmayberry is offline   Reply With Quote
Old 04-23-2013, 11:25 AM   #2
GM
bclemens's Avatar
That fan is probably just the convertor fan coming on. The Arctic Pack are 12v pad heaters on the black and gray tank. If it's going to get cold, make sure the furnace stays on at a decent temp. Keep cabinet doors and closed spaces cracked open slightly so air is getting in there.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 04-23-2013, 12:05 PM   #3
Robert Mayberry
Arctic Pac
Hi BC,
Boy, with you around its like having your own personal tech on board!
It is the converter, under the bed actually. With all the heat ducts running under the bed and behind the fridge, stove and kitchen sink its actually very toasty in those spaces. I've set the furnace at 65 in the day and 50 at night.
Thank you for the advice sir.
Bob
Solera 24S
2011
San Francisco
Old 04-25-2013, 10:41 AM   #4
Robert Mayberry
Another question.
Can you turn on the Arctic Pac while driving down the road or will it drain the house batteries?
Old 04-25-2013, 10:43 AM   #5
GM
bclemens's Avatar
Yes...while driving down the road the alternator would be charging the batteries anyway.
Old 04-26-2013, 11:10 AM   #6
Anacortesians
I have the Arctic pack on my 02 GT. What a stupid system. I expected it to work like frost protection on water pipes at the S&B. No way. The built-in, non-adjustable thermostats come on at 40 degrees F and keep the heat on until they sense that the tank contents reach 65 F.
Who wants to burn 56 Amps at 12v dc (4 pads at 7A each) to heat up the black tank contents to 65 degrees? With the level of contaminants, even in the grey tank, the contents wouldn't solidify until about 28F.
I'm also concerned that there's no protection against the pads being on when the tanks are empty, other than the thermostats. Wouldn't take much to melt through the tank bottom if there was no water in it.
Since we don't use the rig in cold weather and don't keep any liquids on board when it's parked for the winter, I disconnected the system.
Frank and Eileen
No longer RVers or FR owners
Old 04-29-2013, 03:54 PM   #7
Loefflerh's Avatar
You do not have to worry about draining the battery......just on battery power the Arctic Pak will shutoff within minutes, as soon as the voltage goes < 13.3 V it will shut off! Once you put a charge on the battery like driving it will come on again...
Hans
Loefflerh is offline   Reply With Quote
Old 05-01-2013, 10:35 AM   #8
Robert Mayberry
Arctic Pac
Hello,
Well, I'm in Denver now. Six inches snow on ground. 22 degrees predicted tonight. All is well so far. In NW New Mexico it got so cold my water hose froze as stiff as a stick.
Now I'm wondering about the gray water tank and black water tank. My grey water tank is almost empty and the black water tank is 1/3. Will it cause any problem heating an empty tank with the Artic Pac?
Thank you.
Bob
2011 Solera
San Francisco
Old 05-01-2013, 10:55 AM   #9
GM
bclemens's Avatar
Shouldn't be an issue, I'm sure they get turned on with bone dry tanks all the time at shows and on the lot.
Old 05-01-2013, 11:01 AM   #10
CLASS "A" Senior Member
cfsoistman's Avatar
Can't imagine you would have any problems with anything melting. I have the same pads on the elbows at my discharge lines. The pads shouldn't get hot enough to do damage to any of the tanks. If you're still worried, add some RV Antifreeze to both tanks with some water.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
