Old 08-18-2013, 08:49 PM   #1
Aux propane tank kit.
I am looking for recommendations on a kit to enable me to connect an extra propane tank to the Solera.
Any advice appreciated.
2013 Solera S
CHILL is offline   Reply With Quote
Old 08-19-2013, 12:51 PM   #2
2012 Solera
Camco Extend-a-stay? Camco 59123 RV Propane Brass Tee with 4 Ports and Extension Hose:Amazon:Automotive
I've not installed or used one. No idea how hard to install or how well it works.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 08-19-2013, 08:19 PM   #3
papap's Avatar
Works great
Installed it myself in less than 2 hours. Had to go get a couple of short nipples.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 04-09-2014, 05:29 PM   #4
Thanks for the picture. As a newbie wanting to add a tank to my newly acquired Solera, can you tell me what you mean by nipples?
Steve
plstaylo is offline   Reply With Quote
Old 04-09-2014, 08:47 PM   #5
2018 FR3 30DS
Nipples are short pieces of pipe usually threaded on both ends. Get them at any hardware store.
Slow_movin is offline   Reply With Quote
Old 04-09-2014, 10:06 PM   #6
Thank you! Much appreciated. I think the Solera 24R is a fantastic unit, I just want to be able to hook an external LPG tank into the system to conserve the (rather small) inboard tank.
I am a genuine novice- previous experience tent camping and pop up trailer in Australia, and moving up to a sophisticated motor home like the Solera is a daunting , but exciting task.
All hints and helps like yours makes my learning curve much more pleasant.
Steve
Old 04-20-2014, 09:49 PM   #7
Went to camping world and bought kit they sell for $89. And they install it for $39. They had it done in less than a hour. It has a connection for a spare propane tank and one you can run to a grill. The. Kit is called stay a while or extend a stay deluxe. It works great.
Sent from my GT-P5210 using Forest River Forums mobile app
Goat_7 is offline   Reply With Quote
Old 04-27-2014, 05:57 PM   #8
Easy Squeezy
I was able to put the extenda kit into the Solera in about 15 minutes- no dramas nor hassles, something was very easy for once - a crescent wrench and a bit of teflon tape for insurance. A cinch, even for a beginner like me, no extra bits needed.
Works like a charm- heartily recommend doing this- will cut down on LPG hassles with the onboard tank tremendously.
Old 05-06-2014, 08:30 PM   #9
I have just installed the extenda with an auxiliary tank. Trouble is, the auxiliary will run a couple of burners on the stove only, but will not run the generator - insufficient pressure/flow from the auxiliary via the extenda. Have you been able to run a high flow on board system using this?
Old 05-06-2014, 08:43 PM   #10
papap's Avatar
Ran my generator with no problems off extend system.
tank, propane
