Old 09-10-2015, 01:58 PM   #11
GerryW's Avatar
I got vinyl gutter at Home Depot for about $7, My 2300 has a gutter so it works fine, I have had it for about 6 months and it's holding up fine. Make a BIG sign to put on your dash. Bad news if you drive with them in place!
GerryW is offline   Reply With Quote
Old 09-10-2015, 10:06 PM   #12
So I assume this cover is made of plastic or vinyl/ Is it a piece of vinyl eaves trough. ?
I work at Home Depot and not sure of what you are using. How do you keep it fastened to the toppers or the awning. ? Or is it just for the awning ?.
Need more details/specs
Brandon 2
brandon 2 is offline   Reply With Quote
Old 09-10-2015, 10:55 PM   #13
Left Coast
Brandon 2
Haven't seen the right shaped plastic gutter at HD....needs to be the style Lowes carrys.....look'n from the end, is the same shape from top to bottom on both sides...HD's, at least here, is a directional type meaning at the top of one side it has a lip to slide under roofing material..I just turn the open side of gutter down and push it down...holds it self on over awning material...this is only to protect it while storr'n rv...yes to what you called it.
Old 09-11-2015, 01:45 AM   #14
slipf18's Avatar
Awning cover
I have a better idea...the big box stores sell collapsible, accordion style lightweight 5-inch drainpipe. Expandable to 15 feet...for about ten dollars. Get a length, and while still in the collapsed state, run it through a table saw two times, cutting a three inch wide gap lengthwise along the hose. Expand the hose and simply snap it over your rolled awning. Easy on and easy off...plus it collapses for easy storage.
2017Winnebago 2500RL, Hobie Odyssey
Aspen 5.7L HEMI V8,Tekonsha P3
Blue Ox 1500 WDH Airlift 1000# bags
Barker 3500 Tongue Jack
DW & a feisty Border Terrier named Painter
slipf18 is offline   Reply With Quote
Old 09-11-2015, 01:47 AM   #15
I love it. I'm going to install mine this weekend.
barrie1 is offline   Reply With Quote
Old 09-11-2015, 09:43 AM   #16
Mikegjax's Avatar
I like the idea of the collapsible tube. My question; does it give 100% coverage up to the awning attachment point or is there a small area exposed to the elements?
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 09-11-2015, 09:46 AM   #17
Mikegjax's Avatar
[QUOTE=bob caldwell;980473]Haven't seen the right shaped plastic gutter at HD....needs to be the style Lowes carrys....
In my area HD carries the correct shaped gutter that will hook into the RV channel. Lowes carries two types without the lip.
2014 Solera 24R
USN Retired
Old 09-11-2015, 09:49 AM   #18
Georgia Frog Rally 2018
aceinspp's Avatar
Originally Posted by gary ca View Post
Good job Mike; I bought the pre-made pvc ones at the Rv show $$$ darn.
Yep I also bought them now I do not need them as new camper has built in ones. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 25
Old 09-11-2015, 09:51 AM   #19
Left Coast
Wouldn't depend on how one trimmed the ends....lot of work verses climbing up a ladder, plus a lot of awnings are 16+ feet...gutter comes in 8' foot lengths and you can just slide the two to whatever length needed.
Old 09-11-2015, 10:04 AM   #20
Left Coast
[QUOTE=Mikegjax;980753]
With the lip being on the top edge, when you turn it to the bottom the rest of gutter is higher up. To me, that would keep it above the material and I don't think there's enough flex in lip.,.but, everybody can do whatever works for them
cover
