Old 05-27-2012, 04:51 PM   #11
Herk7769's Avatar
Originally Posted by dunnnc View Post
Why not just bypass the fuse and forget the other two and re-locate the fuse or do the other two have fuses also?
They will get replaced with autoreset limiters if they ever blow.
No need to do anything yet.
This is not helping the OP.
HAM CALLSIGN - KC3FFW
Old 05-27-2012, 10:34 PM   #12
2012 Solera
JamesR's Avatar
Originally Posted by cbenoit View Post
We have a 2012 Solera. Our Dometic awning just stopped working. There is no fuse or braker marked for the awning. No idea where to start looking for the answer. Any thoughts?
This is a possibility but it may be a catch-22:
The connector to the awning motor may be loose! but to get at it the awning must be extended somewhat...
and this from the installation manual:
http://www.dometic.com/enus/Americas...ation-Manuals/
Note: An inline 15 amp fuse (installer supplied) should
be installed between the rocker switch and the 12 VDC
power source on the positive (red) wire.
JamesR is offline   Reply With Quote
awning, led pad
