Old 07-21-2016, 05:07 PM   #1
2012 Solera
Awning Protection
I've read a few posts about awning sun protection when the awning is closed. Seemed like a good idea to me - but the methods didn't sound like they would work very well in my case. Apparently Forest River, some time after my model year, started adding metal awning covers (recent post has indicated they have since stopped) - my 2012 did not have this option. Some forum members have designed covers from aluminum gutters - sounds like a great idea, but I use my Solera every two to four weeks, and being honest with myself, I wouldn't bother to put them on - also, I don't have a convenient place to store them while I am using the MH.
After thinking about this "in the background" for a couple of years, I came up with a plan that would work for me. I decided to cover the inner edge of the awning and the slideout cover with 8 inch Eternabond roof tape. It stays on - no install / remove / store issues. It protects the awning and the slideout cover whenever they are closed. Eight inch covers both nicely when closed. Eternabond has a great reputation for attachment strength and longevity. Finished install today - a few small wrinkles, but came out quite well.
Some pictures - from the top and the bottom partially open and from the bottom closed.
ID:	114864   Click image for larger version
ID:	114865   Click image for larger version
JLeising
2012 Solera "S"
Calif SF Bay Area
JLeising is online now   Reply With Quote
Old 07-22-2016, 07:38 AM   #2
Mikegjax's Avatar
I use vinyl gutters over mine, but your idea is great!!
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 07-24-2016, 07:15 PM   #3
I love the idea and want to do it. Where do you get the Eternabond roof tape as I have never heard of it. Does it just stick on to the awning material?
DRZ2021 is offline   Reply With Quote
Old 07-24-2016, 07:20 PM   #4
Sky&Scuba
kendive's Avatar
And does it come in Black? I have a Black Awning when closed no way would I want to make it white.
2015 F150 3.5 EcoBoost Lariat FX4 502A 3.55 Gears Max Tow KO2 Tires
2017 Grand Design Imagine 2150 RB / Traded in Catalina 253RKS
kendive is offline   Reply With Quote
Old 07-24-2016, 07:56 PM   #5
heavynlori's Avatar
Eternabond comes in several colors including black and also several widths
Sent from my iPhone using Forest River Forums 🇺🇸
heavynlori is offline   Reply With Quote
Old 07-24-2016, 09:08 PM   #6
please forgive my ignorance, but I like this idea and want to be sure I understand it correctly,... did you run a complete strip of the tape from one edge of the awning fabric(top side) to the other, using the trailer side as a side edge and then fold some over to the underside, is that what you mean by "inner edge",... or did you run the full length, tight against the trailer, both on the top and also on the under side, so there's actually two layers?..... also is it just on the fabric, using the trailer side as an edge or is a small amount stuck to the trailer side itself, top or bottom? ...... hope all of that isn't confusing ....... just wanting to know exactly how you did it, because I like it..... thanks
fella10 is offline   Reply With Quote
Old 07-24-2016, 09:24 PM   #7
Sky&Scuba
kendive's Avatar
That's Great. I might look into this. I will be adding a slide awning also. I am going to order and install myself.
Old 07-24-2016, 11:48 PM   #8
2012 Solera
Got the 8 inch Eternabond from Amazon - a 50 foot roll for about $120. Used about half between my awning and my slideout cover. I think I have enough left to cover the front and back cap-to-roof transitions, should that become an issue (so far, on my unit, the Dicor has held up satisfactorily).
I ran a strip along the edge where the awning material is attached to the MH from front to back. No overlap of edges - just cut off even with the edge of the awning. No coverage on the bottom - my goal is sun protection while the awning and slideout are "in". In my case, most of the time. By just covering the top inside edges of the awning and slideout cover, the "roll up" of the material when closing the awning or the slide isn't effected. The Eternabond never enters the roll - just covers the exposed material when rolled up.
As someone else noted, I believe Eternabond is available in other colors - my awnings are white adjacent to the MH, so not an issue for me.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 07-25-2016, 12:55 AM   #9
got it now, thanks
Old 07-26-2016, 08:11 PM   #10
to anyone who, like me, is considering this mod and needs black EternaBond because you have a black awning, ..... the link below is an ebay site I found with 8"x50' Black EternaBond for a very good price w/free shipping plus the option to "make offer", ...... I've ordered mine and wanted y'all to know about this site,.......happy trailering.................
8"x 50' Black Eternabond RV Roof and Leak Repair Tape Free Priority | eBay
awning
