Old 12-16-2017, 09:19 AM   #1
Back-up Camera Monitor will not hold settings
Our monitor displays “backwards” (showing cars on wrong side of 2 lane highway. We have to repeatedly hit “M” to get the view to reverse and a bump in the road or turning off the engine and restarting makes have to reset it again because the settings don’t hold. Any fix that you know of to avoid the picture flipping like this?
Cemmett is offline   Reply With Quote
Old 12-16-2017, 09:55 AM   #2
Mikegjax's Avatar
You might try resetting the control box by disconnecting it for 30 seconds. The control box for mine is behind a small dash panel just above the fuse box. One torx screw holds the cover on and is easily removed. While having access I would check the monitor and camera connections.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
