Old 07-13-2011, 04:50 AM   #1
ilmor's Avatar
Backwards Faucets
How many of you have Soleras in which your shower and sink faucet knobs turn the wrong way? I think its the hot water knob specifically, it turns off from the opposite direction that it should.
At some point I'm going to have to see if I can correct this; very annoying esp. when one needs to turn down the hot water quickly in the shower!
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 07-13-2011, 05:05 AM   #2
Outside shower same way? Youroo!!
Old 07-13-2011, 05:39 AM   #3
ilmor's Avatar
My Solera does not have an outside shower.
Old 07-13-2011, 05:55 AM   #4
My showers discharge hoses came out of the (top) from the Factory,I turned them over to the (bottom),now they work correct! Youroo!!
Old 07-13-2011, 06:17 AM   #5
DAISY BOYKIN's Avatar
Faucets mounted upside down
Shower faucets and outside shower controls are mounted upside down. The shower control should have the hose coming out the bottom. If you look closely there is a drain hole in the top (this should be on the bottom)
You have to remove the complete assembly from the shower wall, disconnect the hot & cold connection (be careful you don't drop the sealing gaskets) turn the complete assembly over reconnect the water lines, check for water leaks before remounting the assembly. Re-caulk. Reinstall the valve cores (don't mix them up). When finished, swap the "H" & "C" inserts on the knobs.
This should correct the wrong installation at the factory by a "BUBBA" worker.
There was a quite lengthy post about this problem of the wrong installation on a earlier post.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 07-13-2011, 07:45 AM   #6
realebill's Avatar
the faucet in the shower in my rockwood also works backward. i can't turn it over because it has a tub filler spout. don't know why they would put a "tub filler" faucet in a spa shower. the base is not deep or big enough to use as a tub.Hmmmmmm, maybe the wife could use it to wash clothes in.
2008 rockwood signature ultra lite 8315SS[SIGPIC]
realebill is offline   Reply With Quote
Old 07-13-2011, 08:20 AM   #7
Herk7769's Avatar
Photo please. Are you missing the hose and wand from your camper?
HAM CALLSIGN - KC3FFW
Old 07-13-2011, 09:00 AM   #8
Forgot mention about -----------
Forgot mention about correcting the outside shower, very easy. Get access to the rear of the outside control (WHERE HOT & COLD CONNECT)
remove the cold and hot lines, switch the two. Put the hot where the cold is and put the cold where the hot was. Now switch the "H" & "C" inserts on the control knobs.
This is the quick fix for your outside shower.
Old 08-09-2011, 08:44 PM   #9
we have a Wild cat and the bath room vanity and the shower turn the wrong way. would this be a warranty repair.
ksmharris is offline   Reply With Quote
Old 08-09-2011, 09:35 PM   #10
Bilcin's Avatar
I have a 2011 Wildwood 26TBSS and I have the same problem, all faucet handles are backwards. Are they supposed to be this way?
Bill & Cindy McKenna
Philadelphia PA
2015 Palomino Puma 32DBKS
2005 Ford Excursion 6 liter Turbo Diesel
Bilcin is offline   Reply With Quote
faucet, shower
