Old 11-08-2015, 07:17 PM   #1
Batteries
Want to use battery tender on my 2008 Sprinter Solera 24S while in storage. I am assuming this would be connected to the starter battery in the foot well. What is proper process for hooking up? I have removed coach batteries for inside storage.
alaska6580
alaska6580 is offline   Reply With Quote
Old 11-08-2015, 07:27 PM   #2
Bluepill's Avatar
Yes, just connect the maintainer to the chassis batteries.
2008 Itasca Meridian 37H
Old 11-09-2015, 05:49 AM   #3
Mikegjax's Avatar
alaska6580
In the engine compartment are two posts for connecting cables/charger to the chassis battery. Ground post (-) on the driver side fender wall and red positive post (+) on the engine. The red cover pushes back to expose the positive post.
There is also a nice flat area to set the battery tender.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 11-09-2015, 02:59 PM   #4
MNtraveler's Avatar
Good info, thanks! Gotta look in that footwell again - I didn't see anything the first time around. Thinking they don't want us peons messing with it!
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 11-09-2015, 03:04 PM   #5
Flybob's Avatar
The Battery tender should come with a short battery connection cable with a connector on one end. You can permanently leave this connected and just run the connector our of the battery box and connect the tender to it as needed. Be sure to connect the battery tender to a separate power source, not the AC in the unit as that will require the converter to to be powered up.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
battery
