Old 04-03-2013, 07:40 PM   #1
Loefflerh's Avatar
Battery Isolator-12V from Ignition
Anybody knows were the wire from the ignition to the bayyery isolator manager is coming from?
Reason for my question: coach battery is not getting charged while driving, and my guess is it is not the BIM or the relay - just not getting the 12V from the ignition,
I addition, the slideout and the awning should be blocked out with the ignition on - it is not. I guess it is the same problem not having the 12 Volts from the ignition getting back to the control center. I believe the orange wire should bring the voltage to the circuit board (it is not) and then a red one should supply it to the BIM....
Where does that wire from the ignition originate, is there a fuse in between somewhere?
Any help is appreciated.....thanks
Hans
Loefflerh is offline   Reply With Quote
Old 04-04-2013, 07:46 AM   #2
Loefflerh's Avatar
My hope is that one of those knowledgable factory reps will chime in....there is a orange wire going into the circuit board on the left of the Battery Manager, and I think it is labeled IGN IN. To the left is a red cable coming out of the circuit board going into the Battery Manager...
So I believe not getting the 12 v thru that orange wire into the circuit board (never, ignition on or even with running engine) does not power the BMI!
I am hoping that there ia a fuse somewhere in that orange wire from that circuit board leading to the ignition....I just need to find it.
Old 04-04-2013, 04:43 PM   #3
GM
bclemens's Avatar
I'll ask the engineers. At one time I thought Mercedes did not want us to tie into their battery system. So who knows. As for the slide being blocked out, I would not be so sure about that. We just started the ignition block out recently.
I know some people were like "what if a kid hits the slide button while driving" but its not like the slide out goes out instantly. You have to push and hold the button and you'd hear it for sure.
Nonetheless, I'll see what I can find out. What year? Floor Plan?
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 04-05-2013, 07:28 AM   #4
Loefflerh's Avatar
Bclemens, thank you for helping! Its a 24R, 2013 - brand new,got it 10 days ago.......it never worked! I hope its just a fuse or maybe they forgot to hook up the cable to the ignition???????
Hans
Old 04-09-2013, 01:16 PM   #5
Loefflerh's Avatar
After countless hours I solved my problem!
I am a bit disappointed about the FR service....I was in phone contact first with the dealership in Des Moines....I did not get much help from there. Instead I was told to go to next FR authorized warranty center, a camping world 45 miles away. They just scratched their head, unable to do anything..(at least the did not charge me)
Next day off in the opposte direction - 55 miles away, a big place with at least 2 Soleras on the lot: You did not buy from us, no warranty work...
Called another place and actually got an appointment for the coming Wednesday: "....but this is a strange problem, we doubt we can fix it" !!!
On the phone again with the dealership and got a phone number directly to FR, and that person was really helpful by asking the experts in the plant. At least he found out that that orange cable I was talking about in my first post is connected to the steps...there should be an inline fuse and that one most prob is blown...(there was no fuse)
That was the first clue. With the switch for the steps in the Off postion and the ignition ON the steps did not retract during the demo, and I was told the switch has to be in the ON position to make it work - that was wrong.
So I started digging away the foam behind the steps .....found a yellow blank cable with blank ends (coming from the steps) and a blank orange cable embedded in the foam pretty quick - but still no power with ignition on.
More digging and another hour laying underneath the coach I found a 3rd blank (orange) cable - and that carried the 12 V from the ignition. Actually the wires were a bit to short, and I guess when they were pushed up and back somebody ripped them off and covered the whole mess with foam.
Off to the next auto store, got a roll of wire, a crimping tool, connectors, tape and foam - total of 45$ in Parts. Connected everything - now my coach battery is charging while driving, steps retract when I turn the ignition, awning and slide do not move anymore with the engine running..
I saved FR a lot of money, but when I asked whether they at least chip in for the fuel burned and the parts....negative....and all that with a brand new MH...
Old 04-09-2013, 01:21 PM   #6
GM
bclemens's Avatar
Who told you "negative" on reimbursing for parts?
Old 04-09-2013, 02:42 PM   #7
That's pathetic. Forest River needs to completely rethink and re-engineer its customer support. From NO MANUALS to NOT MY RESPONSIBILITY responses, I'm surprised FR stays in business, particularly since the RV market is both small enough for word to get around and it's a business where repeat customers are important. If a car dealer ever denied taking a look at a possible warranty problem for a car purchased from another dealership, they would put their own dealership into jeopardy. But I guess Warren Buffet doesn't give a sh** about FR's longevity - he's going to be dead soon anyway. Just sell as many as quick as possible using the 1970's US car manufacturing theory that if it goes out the factory door broken, the dealer will fix it. But in FR's case, it goes out the factory door broken AND THE DEALER WON'T FIX IT EITHER.
Don Wills is offline   Reply With Quote
Old 04-09-2013, 02:50 PM   #8
GM
bclemens's Avatar
Whoa, whoa, whoa. Someone's had a bad day.
Before jumping to more conclusions, he never said who said "no". Which is why "I" the factory that does not care, has asked.
So Loefflerh, please PM me the dealers you spoke with as well as who told you "negative". I am 100% sure we can come to an agreement.
Old 04-09-2013, 02:59 PM   #9
"You did not buy from us, no warranty work..."
Is that FR's policy? Dealers may refuse warranty work if not purchased there?
Old 04-09-2013, 03:25 PM   #10
GM
bclemens's Avatar
On every brochure we explain our policy and on the dealer locator shown here...
Forest River RV Dealer Locator :: Forest River RV
These are independently owned and operated dealerships. This is not "our" policy, this is a dealer choice.
Just about every other RV mfg has similar language on their website (I know, I've looked). A Ford dealer could tell you to take your unit elsewhere...it's just not in the best interest of that dealership.
Before we make a mountain out of a mole hill...he was given multiple dealerships that would do the work even if he didn't buy from them. I rarely see this come up (just search the forum) and we don't know the whole conversation, they could have had a backlog of their own customers already.
I will say all dealers are expected to (and from what I can tell, do) service your unit as a priority if you are traveling outside of your home area.
