Old 03-22-2014, 08:14 PM   #1
Big foot remote
We had to get a new remote for the rear stabilizers. It came with no instructions on how to sync with the system. Any suggestions?
Trail blazer is offline   Reply With Quote
Old 03-22-2014, 08:33 PM   #2
2012 Solera
JamesR's Avatar
try this
from the user manual:
To sync your key fob to the receiver…
1. Press & Hold the on/off button on the receiver until the light on the receiver starts to flash.
2. Press & Hold the on/off button on the key fob until the light on the receiver turns constant
assuming the replacement remote is the same frequency?
http://thebigfootleveler.com/uploads...ing_Manual.pdf
JamesR is offline   Reply With Quote
Old 03-22-2014, 11:35 PM   #3
I received a replacement remote from Big Foot and have been unable to sync it with the receiver following those instructions, which were the same also provided with the remote.
RMThomas is offline   Reply With Quote
Old 03-23-2014, 07:31 AM   #4
Thanks for the suggestion, I will try today and let you know if it works.
Old 03-23-2014, 09:02 AM   #5
MountainTrippers's Avatar
Bigfoot Stabilizer Brain teaser Fix
Here are the factory instructions
George & Karen
2014 F150 4X4 5.0L 3.55 Axle
Husky Centerline TS 1200lb 4 point WDH
2017 Rockwood Mini Lite 2109S
Palmyra,VA
MountainTrippers is offline   Reply With Quote
Old 03-24-2014, 08:13 PM   #6
Well I tried both suggestions, no success. I will try Kevin Deal the lead engineer mentioned in the post. Thanks for the help.
