Old 01-16-2014, 05:11 PM   #11
Mikegjax's Avatar
I have a 2014 24R and I also looked at a 2013 24R and the Bigfoot controls were in the large rear storage compartment, drivers side, front wall near the top. Strange that yours are not in the same place. Maybe yours were an add on after original build.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 01-16-2014, 07:31 PM   #12
hkreck's Avatar
Goat_7
My controls didn't look like and were not marked as controls for the jacks. They just looked like regular switches. I found out what they were when I pushed them to see what they did. I just find it hard to believe that the remote is the only controls on your rig. Look a little harder.
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 01-17-2014, 06:39 AM   #13
MountainTrippers's Avatar
Bigfoot
Originally Posted by Mikegjax View Post
Goat 7, you never did say if the on board controls worked or not.
My unit was working but was acting erratic. I sent you the info because someone said maybe you needed to re-pair the remote. The remote is only a transmitter and must be paired with the receiver to make the transition to the pumps that work the levelers. So keep looking for the receiver. Maybe MR B can help. The receiver looks just like the remote but bigger.
George & Karen
2014 F150 4X4 5.0L 3.55 Axle
Husky Centerline TS 1200lb 4 point WDH
2017 Rockwood Mini Lite 2109S
Palmyra,VA
MountainTrippers is offline   Reply With Quote
Old 01-17-2014, 07:23 AM   #14
Bigfoot
Thank's for all the help. We went home for the long weekend but will go back to the campground Tuesday and will check it out Thank You
Goat_7 is offline   Reply With Quote
Old 01-17-2014, 11:07 AM   #15
hkreck's Avatar
Goat_7
I had to almost put my head into the compartment to even see the switches for my Bigfoot. Guess they put them up high so nothing will hit them while traveling?
Henry & Tena
2013 Solera 24S
The Great Escape
Old 01-20-2014, 07:22 PM   #16
Found the control It was with the tank under the coach between the spare and rear axle. You had to take the cover off and I synced the remote. I don't know why they didn't put it in a storage compartment it was not a add on and came from the factory like that. I'm back in business now. Thanks to everyone
Sent from my GT-P5210 using Forest River Forums mobile app
Old 01-21-2014, 07:07 PM   #17
Bigfoot Stabilizer
Glad it worked out. That is a strange place for it.
George & Karen
Palmyra,VA
Old 01-28-2014, 01:11 AM   #18
boats742's Avatar
mine was in the same location on the ram by the rear axel... My control board went bad (did not pair well with the remote). Bigfoot sent me a new board with the longer wiring harness, and I had the control installed in one of the outside storage compartments like the build them now. Otherwise you would have to crawl underneath the RV to manually move the levelers or re-pair the remote.
2013 Solera 24S
Charleston, SC
boats742 is offline   Reply With Quote
Old 01-28-2014, 05:45 PM   #19
I think I might get a hold of them and see if I can get the extension and move it. It is a pain to get to. Thanks
Old 02-12-2014, 07:35 PM   #20
I could not get mine to work either, even after resetting the remote. You did try initializing the remote didn't you? Anyway I called Forest River and they sent me a new remote and a new control unit. That worked.
bgc44a is offline   Reply With Quote
