Originally Posted by dukeboone
Thanks. I'm definitely not going to connect to anything without the proper knowledge and yes I agree it's likely the same wiring harness for multiple models. Thank you for your reply. I did research on the Bigfoot website but couldn't find a wiring diagram for that switch. Cheers!
You might look at the back of your control panel and see if there a black wire hooked to it. I always assume which makes me a you know what, that black is a ground. They might have found a ground closer. If it is a ground you will blow that relay. Most of the time grounds are black but in the RV it self they use white which makes no sense to me at all. But any components are mostly black for a ground.....
I think that there is rep that checks in on your unit, I can't remember his name but maybe he will catch your post.
