There is a breaker under the rig trace the power cable coming off of the battery should go right to it. Something's Quadra suggest for this problem is check both positive and Negative 12V connections, check for a full charge on the battery, check that the tank assembly has proper ground and check the wiring. Not sure if the breaker has a reset. Good luck.
Henry & Tena
