Old 11-04-2013, 11:24 AM   #41
Turbo, when you say "I've not seen much" can you help out a bit more. Bio % observed, etc. Thanks.
2012WhiteSolera is offline   Reply With Quote
Old 11-04-2013, 11:31 AM   #42
TURBS's Avatar
Localy 0% bio in any percentage.
Eastern Iowa.
Old 11-04-2013, 11:39 AM   #43
TURBS's Avatar
And didn't see anything from Dubuque Iowa to Boulder junction Wisconsin.
Old 11-04-2013, 08:07 PM   #44
mckirby50's Avatar
Went through Texas New Mexico and Colorado this summer starting in Oklahoma and never used any over 5%. I don't like using the big rig pumps and haven't had any trouble yet. We ran across 20% a couple of times but it seems like it was coming home from Florida, didn't use it just kept going till we found 5%. I'm usually ready to stop and fuel up by the time we've used 3/4 tank or couple hundred miles!
mckirby50 is offline   Reply With Quote
Old 11-04-2013, 09:16 PM   #45
Where do you find the % sticker? I have not had any luck. Thanks
13larry is offline   Reply With Quote
Old 11-04-2013, 09:28 PM   #46
TURBS's Avatar
Originally Posted by 13larry View Post
where do you find the % sticker? I have not had any luck. Thanks
Old 11-04-2013, 09:32 PM   #47
So no BioDiesel label means it is good to use??
Old 11-04-2013, 10:08 PM   #48
TURBS's Avatar
Pump should be clearly labeled.
Old 11-04-2013, 10:10 PM   #49
mckirby50's Avatar
Haven't seen diesel that cheap in a while, staying between $3.60 & $3.70 around here!
Old 11-05-2013, 09:32 AM   #50
Arefbee's Avatar
Don't they grow a primary component of bio-diesel in Iowa?
2011 PrimeTime Tracer 2600rls
2001 GMC Yukon XL 2500, 6.0L 4.10:1 axle ratio
Nights camping 2014 - 17
2013 - 15
Arefbee is offline   Reply With Quote
