Old 07-03-2015, 04:56 PM   #11
kirkwood721's Avatar
So where is this "fullway termination valve" located? Just purchased a 16 36QBOK and am wondering the same thing. I hooked a hose to the black tank flush valve and opened the black tank and still couldn't get the water to flow into the black tank. I did not have this feature on my last camper so we just took a hose in and put water directly into the toilet, so if I can figure this out it would be much more convenient. Although I bet it is not tied into the rear black tank since this new camper has two black tanks..
kirkwood721 is offline   Reply With Quote
Old 07-03-2015, 06:52 PM   #12
Mikegjax's Avatar
"fullway termination valve" fancy description of black tank drain valve. If you can't get water into the tank, check the screen in the inlet and there might be a check valve stuck closed.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 07-03-2015, 06:57 PM   #13
Or installed backwards.
Old 07-03-2015, 07:42 PM   #14
Thanks I will look for a check valve. It has to go back to the service dept. in a week or so to get a new fan in the bathroom that they haven't installed yet. So I might jest make them fix it!
Old 07-04-2015, 05:38 AM   #15
Mikegjax's Avatar
Best idea!
2014 Solera 24R
USN Retired
Old 07-04-2015, 07:37 AM   #16
My wife is already mad about all the things I've already fixed but I can't just stand there and let my camper get ruined! This is the first time we have had it out and we bought it brand new. I have fixed a blown water line that soaked the underneath storage, removed a screw and a staple out of the floor of the rear slides that scratched our floor. Had to re-caulk the shower because the bottom track on the glass slide door wasn't sealed properly and the first time we took showers we got about a gallon of water on the floor in the bathroom. I have a valve broken on the stove top, and I had to shim up the slam latch catches on two of the storage doors because even locked you could just grab them and open the doors... Very frustrating after paying this much money! But hopfully they will get everything fixed and re-imberse me for my time and what I've already done for them!
Old 07-05-2015, 10:13 PM   #17
KIrk,
You reached the Solera specific forum. Sorry for your travails, but other not sure your experience in this area is of mush help to us. And a quick reading of your QA issues wrongfully disparages the Solera.
2011 Solera 235S
Freightliner Badge
cousin01 is offline   Reply With Quote
Old 07-08-2015, 04:04 AM   #18
Sorry, I thought this was a forum for all Forest River products. My Sabre is made by Forest River.
Owner= Kirkwood Auto Glass
Camper= Sabre 36QBOK
Tow rig= 07 Silverado 2500HD
Old 07-08-2015, 10:40 AM   #19
2012 Solera
This is the Solera MH sub forum section. Think you will find the correct sub forum for your Sabre here: Palomino - Forest River Forums.
Forum structure can be confusing.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 07-08-2015, 12:01 PM   #20
Okay, what's a cable valve? As opposed to what? Thanks.
lacamastraveler is offline   Reply With Quote
black, black tank, black tank flush, tank
