Old 10-03-2014, 09:49 AM   #11
GM
bclemens's Avatar
Check valve
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 10-07-2014, 04:04 PM   #12
where is the check valve?
i just tore the compartment apart and can't find it... hose runs up into a 3" black pipe with all the other hoses - no sign of any valve on the black tank flush line. is it on the tank itself? photo, please!
tommyb is online now   Reply With Quote
Old 10-07-2014, 04:19 PM   #13
TURBS's Avatar
Right at the hose connection.
Or should I say just behind it.
Turbs
Old 10-07-2014, 05:08 PM   #14
Carefully take out the washer with screen and you'll fund the check valve pictured below. You might try pushing in the white piece in the middle to see if it's stuck. Just stand off to the side when you do.
Name:	check valve.jpg
Old 10-07-2014, 05:33 PM   #15
that is absolutely not on my solera. i removed those three screws you see in the photo, then the clip behind. i reached behind the panel and removed the compression nut. i held the hose fitting in my hand, peeked through it, and it is a clear hole... no check valve. i examined the hose, and traced it up into the 3" pipe, looking for an inline check. there is nothing in the compartment... and yet water will not enter the black tank. the mystery continues....
Old 10-07-2014, 06:18 PM   #16
EJM4's Avatar
Same situation in my motorhome. It used to work. I chalk it up to something (paper) getting dried on the nozzle inside the tank.
Earl
2013 Berkshire 390BH / 360hp
EJM4 is offline   Reply With Quote
black, black tank, black tank flush, tank
