Old 07-05-2011, 11:00 PM   #11
Herk7769's Avatar
Originally Posted by papap View Post
Do you have to install the steel stems for the TST system?
These are highly recommended in any case; but for a TPMS they are almost mandatory. With the pressure cap in place the centrifugal force at 60 MPH will bend the rubber ones until the cap touches the rim. This is VERY hard on the stem and the pressure cap.
I took mine off completely because the TPMS (supplied as a VERY expensive option) was bending the rubber stem to the point it was leaking. I now have steel stems, but never bothered to put the supplied TPMS caps back on because they only alerted at 25 PSI. Since I had C rated tires running 50 PSI (before I upgraded to D rated ones) they were damn near useless. 25 PSI is a blowout already happened.
HAM CALLSIGN - KC3FFW
Old 07-06-2011, 04:55 AM   #12
ilmor's Avatar
Question - do tires need to be removed from the rims to install steel stems?
2017 Forest River Sunseeker 2250SLE
ilmor is online now   Reply With Quote
Old 07-06-2011, 05:26 AM   #13
Yes. I took mine to Big O and they installed the four new stems, balanced the tires (all four where way off balance) and filled the tires with nitrogen.
Cost was about $60.
They jacked up each side of the TT with two floor jacks. One side at a time. I also made sure they torqued the lugs to spec.
2012 Rockwood Signature Ultralite 8281SS FW
2009 Nissan Titan LE (SWB 4x4)
kgmat is offline   Reply With Quote
Old 07-06-2011, 06:45 AM   #14
MtnGuy's Avatar
Cost was about $60.
I had the steel stems installed and tires balanced on all 4 of my trailer trailer tires with a 80% nitrogen fill for $36.
Old 07-11-2011, 04:31 AM   #15
ilmor's Avatar
Update - I'm taking her in for steel stems this coming Saturday. I'm ordering a new wheel simulator and extenders from my dealer (he is far, far away but can get them for me and ship - and wow, they are impossible to buy "online"). I will also be purchasing a TireTraker system.
Old 07-17-2011, 10:15 AM   #16
ilmor's Avatar
Update #2 - stems had to be ordered; so I take her in next Sat. for the installs...
Old 07-18-2011, 11:53 AM   #17
Villa Estate 392FLFB
The_Stuff's Avatar
so are both of your stems going to be easily accessible when you are done and ready to roll?
i have to change the dually stems on my bus.. they are steel and nubs and you have to have a special air chuck to get on to fill or even check the pressure!
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 07-18-2011, 03:46 PM   #18
ilmor's Avatar
Thanks for asking; yes, I will also have valve extenders as necessary, and then my TireTraker system on top of that!
Old 07-20-2011, 09:36 PM   #19
papap's Avatar
Has anyone used this brand?
6 Tire Pressure Monitoring System SALE PRICED at $299 - Truck System Technologies, Inc.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 07-22-2011, 05:55 PM   #20
ilmor's Avatar
Update #3 - Dealer ordered wrong stems; since I'll be out of town next weekend now I'll have to wait two more weeks until metal stem install.
blowout, good sam, solera, tire
