07-04-2011, 07:56 PM
Blowout!
Hello all,
I just joined the forum. We have an '09 Solera which we purchased new early last year. Currently we have a little over 8K miles on it. We love this motorhome! But, we did have an incident yesterday...
While traveling home yesterday, 2 hours from home driving 12 hours, we heard a loud "woosh", soon followed by a lot of loud thumping. We pulled over and found both RR tires FLAT.
We are not sure what happened, but based upon the sequence of events it appears that all this was caused by a faulty extender, which failed on the inside tire, causing the woosh, and after that tire went flat the overloaded outside tire lasted only a while longer then blew from the load!
Thanks to the Good Sam Roadside Assistance we were back on the road in 3 hours. Great service, especially considering it was a holiday weekend.
The inside tire appears to be fine, is still holding air and is now our spare. We replaced it with a new tire, and put the original spare on the outside. Now I also need to buy a new chrome wheel simulator and extenders as all of that flew off and was lost during this event.
Never a dull moment....
07-04-2011, 08:36 PM
49 year camping veteran
Glad you fared well on the repair. Road service is a life-saver!!!
After a couple of similar blowouts with my Dad on his class C mini, tracked it down to the extender tubes going bad and having slow leaks causing the blowout.
Got rid of them and no issues since. Little tougher to get in and measure pressure / add air.
Whatever direction we're traveling, that is the way the wind is blowing from.
2011 Rockwood 2604
1995.5 F350 CC4x4 PSD
07-05-2011, 12:07 AM
Start looking at a pressure monitoring system. It'll give you a hint of a problem before it becomes a REAL problem. IMHO, well worth the investment!
Fire Instructor
2022 Coachmen Leprechaun 319MB
2022 Ford Ranger toad
07-05-2011, 06:30 AM
What pressure monitoring system would you advise on. I'm looking to purchase one also
07-05-2011, 07:34 AM
I use the Pressure Pro, and I like it very much. That said, since I bought mine, more than one brand now offers units with batteries that the user can change, rather than send the sending units back to the factory every few years, so If I had it to do over again now, I might have purchased differently...
Fire Instructor
07-05-2011, 07:40 AM
I also use Pressure Pro. I had sensor go bad in 4 years, and Pressure Pro replaced that for $30. Batteries have not been needed to be replaced yet. The system works great.
07-05-2011, 05:48 PM
I'm looking at Pressure Pro and Doran systems. The equivalent Doran costs $85 less based on MSRP...
former 2017 Forest River Sunseeker 2250SLE owner - replaced by a Pleasure-Way Tofino and then an Ontour 2.0
07-05-2011, 07:11 PM
Found the TST system with 6 moniters for 299. RV Tire Systems
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
07-05-2011, 09:29 PM
Do you have to install the steel stems for the TST system?
07-05-2011, 11:00 PM
These are highly recommended in any case; but for a TPMS they are almost mandatory. With the pressure cap in place the centrifugal force at 60 MPH will bend the rubber ones until the cap touches the rim. This is VERY hard on the stem and the pressure cap.
I took mine off completely because the TPMS (supplied as a VERY expensive option) was bending the rubber stem to the point it was leaking. I now have steel stems, but never bothered to put the supplied TPMS caps back on because they only alerted at 25 PSI. Since I had C rated tires running 50 PSI (before I upgraded to D rated ones) they were damn near useless. 25 PSI is a blowout already happened.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
07-06-2011, 04:55 AM
Question - do tires need to be removed from the rims to install steel stems?
07-06-2011, 05:26 AM
Yes. I took mine to Big O and they installed the four new stems, balanced the tires (all four where way off balance) and filled the tires with nitrogen.
Cost was about $60.
They jacked up each side of the TT with two floor jacks. One side at a time. I also made sure they torqued the lugs to spec.
2012 Rockwood Signature Ultralite 8281SS FW
2009 Nissan Titan LE (SWB 4x4)
07-06-2011, 06:45 AM
Cost was about $60.
I had the steel stems installed and tires balanced on all 4 of my trailer trailer tires with a 80% nitrogen fill for $36.
07-11-2011, 04:31 AM
Update - I'm taking her in for steel stems this coming Saturday. I'm ordering a new wheel simulator and extenders from my dealer (he is far, far away but can get them for me and ship - and wow, they are impossible to buy "online"). I will also be purchasing a TireTraker system.
07-17-2011, 10:15 AM
Update #2 - stems had to be ordered; so I take her in next Sat. for the installs...
07-18-2011, 11:53 AM
Villa Estate 392FLFB
so are both of your stems going to be easily accessible when you are done and ready to roll?
i have to change the dually stems on my bus.. they are steel and nubs and you have to have a special air chuck to get on to fill or even check the pressure!
One state/province at a time!
07-18-2011, 03:46 PM
Thanks for asking; yes, I will also have valve extenders as necessary, and then my TireTraker system on top of that!
07-20-2011, 09:36 PM
07-22-2011, 05:55 PM
Update #3 - Dealer ordered wrong stems; since I'll be out of town next weekend now I'll have to wait two more weeks until metal stem install.
