Old 04-25-2015, 03:33 PM   #11
My understanding is that the invisi brake is installed in the toad. Its monitor is installed in the RV. the stealth controls either a trailer or a toad. for the stealth to control the toad, its main unit is installed in the toad too. If you hook up a trailer, it controls it the same way any brake controller does, through the 7 pin connector. The invisibrake requires a separate brake controller if you also pull a trailer. I am new to this and getting very confused as there are so many variations to get the job done.
nicktano is offline   Reply With Quote
Old 04-25-2015, 04:15 PM   #12
Sandiegodoug's Avatar
I plug my jeep in with a 7 prong plug
Below the front bumper of the jeep.
It used the solera plug. Controller wired into the dash just above the key .
Sandiegodoug is offline   Reply With Quote
Old 04-25-2015, 04:18 PM   #13
Our Solera is at RV service now for the install and we hope to have it back early next week. As to where to connect I was advised to back trace from the 7-pin connector at the bumper and look for the forest river "panel" ( which depending on your model may be behind a panel in storage compartment or behind the drawers to side of the fridge) and connect on the "out to back bumper " side.
john.tucson is offline   Reply With Quote
Old 04-25-2015, 04:36 PM   #14
Thank you Doug I see you're in San Diego I'm in Bonita.
Old 04-25-2015, 04:36 PM   #15
Thank you John good luck with your install and thanks for the info. not yet sure what I will do but I'll let you know when I decide. thanks again have a great weekend Nick
Old 04-25-2015, 05:35 PM   #16
I live in rancho penasquitos. If you would like to see my set up let me know. My rubicon weighs in at 4k
Solera handled it great but I was not going to cheap out on stopping . I told them to put best system in.
Old 04-26-2015, 01:49 PM   #17
Thanks Doug. it's good to know it pulled 4k easily. I was going to pull a Ford c-max hybrid which weighed in at 3600#, but I heard there are some issues with hybrids so I'm thinking of getting a Ford Fiesta which can be towed 4 on the ground and only weighs 2200#. Planning multiple cross country trips so less weight is better. Still have some thinking to do but I might take you up on your offer in a week or two. thanks again.
Old 04-26-2015, 06:13 PM   #18
2200 you won't even know it back there. We had ours done at San Diego trailer. They set up our jeep so when not towing you wouldn't know there was a system installed. We went with the blue ox system.
brake control, controller, brakes
