Old 04-30-2012, 12:24 AM   #1
Brake Controller Wiring
I have a 2009 Solera; I'm making arrangements to purchase a tow dolly with electric brakes. I'd like to find out if adding a brake controller is plug-and-play with the correct cable? Or will I have to run a separate wire back to the 7 pole connector by the hitch?
Regards,
Davie
DavieBabie is offline   Reply With Quote
Old 04-30-2012, 04:58 AM   #2
Namchief's Avatar
Usually if you have a 7 pole at the rear this means you have a factory wire job and should be plug and play. I am a little confused you have a different vehicle that you want to tow the Solara with right??? http://www.curtmfg.com/masterlibrary..._App_Guide.pdf
Time spent 2012 in TT 32 days so far and 21 Planned days this Fall with mini trips in between
2009 Chevy Silverado 1500
2012 XLR Hyper Lite 27HFS
1999 Yamaha Grizzly
1996 HD Dyna Wide Glide
Namchief is offline   Reply With Quote
brake control, controller, solera, wiring, brakes
