You have the same color scheme as mine. Paint over plastic and vinyl trim is an issue. Vinyl outgases and shrinks, especially when used on an inside radius. The paint will eventually fall off.
I got mine stretched back in, then used 2 aluminum screws on each radius to hold it in place. You can find different colors of these screws, which are made for installing home trim/siding.
You might need to remove the screw at the bottom of the trim and slide the strip upwards to get it back in the radius. Of course, you then have to realign the paint stripes on the strip.
If this happens again, I'll just get a roll of black trim and pop new strips in. I think the black would look good, anyway.
Mark & Susan
Former MBS 24R and 2401W Owners
Just recalibrating our camping set-up for now!
