Old 04-07-2015, 03:56 PM   #11
DW uses the thin flexible cutting boards in all the cabinets. Just slip in behind the door frame and close door. Works great!
2017 RAM 3500 DRW CC Laramie, Curt Q20
2013 CC 36CKTS
Me and DW
2 cats: Bello & Dexter (Peanut) RIP
DavandJane1 is offline   Reply With Quote
Old 04-08-2015, 09:10 AM   #12
Clarification on using a foam rubber pad. Place the items in the cabinet, then place the foam pad (I used some scrap carpet pad) in the cabinet in front of the items and close the door. Hope that clears it up.
edcronin01 is offline   Reply With Quote
Old 04-08-2015, 11:35 AM   #13
I have found a lot of great ideas on Pinterest, one was using a small hand towel bar with the sticky foam backing and adhering it to the wall, then put items behind it and it holds everything in place and doesn't have to be removed to get to items.
Give a person one of your smiles….it may be the only sunshine they see all day!
springfever is offline   Reply With Quote
Old 04-10-2015, 10:25 PM   #14
I took the face trim off of all the shelves and moved them up higher so that the bottom edge of the face trim lines up with the bottom edge of the shelf. As it was, some of the trim piece extended below the shelf, which did no good. Anyway, this fix worked for us. Some taller things still might still lean over sideways while in motion but stay on the shelf. I did have to use new finishing nails and putty the nail holes to camouflage them.
jngspencer is offline   Reply With Quote
