"Cable" problem 2015 Solera 24R
Hi,
OK, I'm stumped. I cannot get the cable connection
to work on my 2015 Solera 24R.
I've read that it could be that I need to shut off the
antenna booster, but.....
I have no idea where to find the antenna booster or
how to shut it off.
The antenna wire and power wire from the TV comes into the cabnet
above the RV door. There is a power plug there for the
TV and a connector for the antenna wire from the TV.
There is also another plug set with a short cable (3 inches) that runs
from one connection to another (makes no sense).
But there is no "green light" and no button to push to
turn anything off. So, can anyone with a 2015 Solera
tell me where to find and shut off the TV antenna booster?
Also, someone said that they found a wire from the outside
cable connector that was not connected. Where do I look
for this problem?
Thanks so very much.
Glider24
