Old 04-03-2013, 06:21 PM   #1
FRESNO FOREIGN
Cable tv stations
Hi folks, I have a 2012 24s and have been to many different campgrounds but can not seem to receive any cable stations. At first I thought it was the campgrounds cable fault,but no, as I was camping with other people and the cable was fine. I pick up very good antenna tv for local stations. I scan for the stations with the tv but nothing comes in. Any ideas? I tried different cables from the coach to the hook up with no change. Maybe B.Clemens has a solution without me driving a hour to a FR dealer. thanks for help in advance!
FRESNO FOREIGN is offline   Reply With Quote
Old 04-03-2013, 06:31 PM   #2
2018 FR3 30DS
Here's a couple of "possibilities..may or may not work". Have you checked the antenna booster to see if it's on/off? Should be off for cable.
And have you set your tv for cable rather than antenna. You might try connecting from the cable outlet directly to your tv. If it works, then that means you probably have a system problem.
Slow_movin is offline   Reply With Quote
Old 04-03-2013, 07:00 PM   #3
dot76's Avatar
Mine has a selector box on the outside of the Telly that I must use to send the desired signal to it. But mine is ten years old so I don't know how much help that will be to you.
dot76 is offline   Reply With Quote
Old 04-04-2013, 06:11 AM   #4
Do these things, I think you will find the problem is one of the above. If the tv works with the antenna then you must change the tv input and the booster for cable, otherwise it wont work on cable.
DebbieMH is offline   Reply With Quote
Old 04-04-2013, 01:25 PM   #5
Another possibility is that they mis-wired (swapped) Sat. & Cable wires, but try those other things first.
Old 04-04-2013, 03:13 PM   #6
bikendan's Avatar
most common cause is the antenna boost button was left on, when trying to get cable.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 04-04-2013, 04:33 PM   #7
GM
bclemens's Avatar
^^THIS^^. turn the booster off. Don't think you would need to change the switch box over to cable since its all the same coax.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 04-04-2013, 06:32 PM   #8
FRESNO FOREIGN
Thanks for the help!, I will look for the antenna booster switch. I dont remember seeing one any where. Where would it be located on a 24s?
My dealer never mentioned it as I recall. Thanks again
Old 04-04-2013, 06:39 PM   #9
Send a message via MSN to Tiggerdad
Usually located next to the cable connector to the TV.Should be lit up when it is on. When you find it, push it in.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 04-04-2013, 07:48 PM   #10
GM
bclemens's Avatar
^^What he said^^ if you have a switch box instead, make sure it is powered OFF. If the switch box does not have a power button on the front (also will light up), then you may need to cut power. I think some of the boxes are hard wired.
