Old 10-06-2014, 07:02 PM   #11
Originally Posted by Still Kickin View Post
I'm not following you. If you pull the cable out and cut it, how do you attach the replacement camera?
You just connect it to the camera - or take the camera apart and disconnect the cable inside (takes 1 minute longer).
Reiner
2011 Solera
reinerka is offline   Reply With Quote
Old 10-06-2014, 07:09 PM   #12
Reiner
Thanks, I never had the camera apart and didn't realize it wasn't that easy as you say.
Old 10-20-2014, 12:56 PM   #13
Talked to a tech at rvcams.com. He said to check the power and ground connections. Anyone have any ideas where those might be?
tommyb is online now   Reply With Quote
Old 10-20-2014, 04:27 PM   #14
OK, took everything apart and have much more info.
The monitor cable passes over the driver's door, and down the pillar behind the driver's door. If you remove the pillar trim , the cable ends in a cluster of wires. It has a red wire and a black wire, which pass through a small black box with a fuse and filter circuitry, then tie in to the 12v system. These red and black wires also connect to the cable which runs to the camera at the rear. A blue wire has been cut off. There is a yellow RCA connector which is unused, and a white RCA connector which connects to an RCA connector which goes to the camera through the floor, inside a corrugated black plastic conduit, along with the red and black power. If you remove the camera at the rear, remove the grommet that the cable passes through, and pull out the caulk, you will find a four pin connector.
I took my camcorder, plugged the output into the white RCA connector, and confirmed that my monitor works. Then rigged a wire to the RCA connector, and connected the bare video wire to the yellow wire that had connected the camera. When that worked, I knew that the cabling was good.
That leaves the camera. I will post again when I have obtained a replacement.
2011, solera
