Old 08-05-2013, 10:36 AM   #1
Can't Start!!
Help! Just returned from weekend camping, unloaded Solera and went out to start it so I could refuel. No sound when key was turned, but EVERY indicator light came on! The engine battery is not discharged, but I am in process of charging it (was 80%) just in hopes this will help. Any ideas please before I call for service - I'm pretty new to this RV thing, so it could be something simple and embarrassing.
RSolera is offline   Reply With Quote
Old 08-05-2013, 10:39 AM   #2
Is it fully in park?
pcmdnh is offline   Reply With Quote
Old 08-05-2013, 10:45 AM   #3
2018 FR3 30DS
Check fuse number 23 in the fuse panel on the firewall under the steering column. Some Soleras had a 20 amp fuse and it should be a 25 amp fuse. Mine did the same thing as yours and that was the problem. If the fuse is blown, replace it with a 25 amp fuse.
Also, sometimes my engine won't turn over but it has a clicking sound. Don't know what this is but I am gonna take to MB service to get it fixed. I can keep turning the switch off and on and sooner or later it will crank.
Hope this helps
Slow_movin is offline   Reply With Quote
Old 08-05-2013, 11:05 AM   #4
Can't start!
Tried rocking RV and made sure it was fully in Park - it was. Then followed SlowMovin's advice. The #23 fuse was blown and as suggested, I replaced it with a 25amp fuse. The engine started right up!! Thank you so much!!!
Now, I have to wonder why Forest River would put a 20amp there and what could be the cause of that fuse blowing???
Old 08-05-2013, 11:15 AM   #5
Displaced2's Avatar
I think that part of electrical is MB and not Forest River.
Displaced2 is offline   Reply With Quote
Old 08-05-2013, 12:43 PM   #6
2012 Solera 24S
This is a Mercedes issue and not Forest River, I had to do the same to mine less than 1 day after I brought it home.
Haven't had a problem since.
Nats is offline   Reply With Quote
Old 08-05-2013, 12:45 PM   #7
Taylorgso's Avatar
Hope this helps
Gotta file this one for future reference!
Ed (N4RWU) & Becky Taylor
Mistie (Walks 4-down)
Greensboro, NC
Taylorgso is offline   Reply With Quote
