Old 01-29-2014, 06:04 PM   #1
boats742's Avatar
Caution with Drained Water Heater
I winterized my Solera and drained the water heater a month ago. Today I brought it to my house and plugged-in the shore power. It kept blowing the breakers within 60 seconds in the house. The water heater was off on the RV systems panel. I could see the RV was pulling amps, so I turned-off the breakers one-by-one and sure enough the electric water heater element was on. Apparently the RV panel only controls the gas part of the water heater, so you have to either throw the breaker or go outside to the back of the heater and throw a switch to off (I read now).
2013 Solera 24S
Charleston, SC
boats742 is offline   Reply With Quote
Old 01-29-2014, 06:08 PM   #2
wmtire's Avatar
Unfortunately, that's the way it works on many Suburban water heaters. This is also a very overlooked thing in PDI/Walk thrus.
Bad news is, you have likely burned out the electric heating element now (thus the breakers tripping)......and it will need replacement.
Instructions/links are here:
Suburban's electric switch and much more
Good news is, you'll most likely only do it once... and after this, you'll know how to replace the element. It happens fairly frequently, thus the reason for the detailed instructions in the FAQ section.
No need to knock yourself over it. It's just one of those live and learn things.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 01-29-2014, 06:08 PM   #3
Mark and Linda's Avatar
I make it a point to flip my breaker inside the travel trailer whenever I am not using the hot water heater. When I pull out the anode for draining, etc. I flip the outside switch. One of my things on my check list. Hey, we are always in a learning process. When I de winterize I will probably forget to flip my switches until the DW complains the water is not getting hot enough.
2009 Palomino Puma 25RS
2007 Chevrolet Silverado
Prodigy P2 Brake Controller
Mark and Linda is offline   Reply With Quote
Old 01-29-2014, 06:09 PM   #4
You found out the hard way. Sorry.
I always open the breaker when I pack up to leave camp, then I can't inadvertently burn it out. When I get to camp, I let the propane heat the water. Once it's hot and I know the heater is full, I'll turn the breaker back on.
2011 Traverse LT, 3.6L, FWD
Old 01-29-2014, 06:23 PM   #5
But always have a spare....
Hudlow is offline   Reply With Quote
Old 01-29-2014, 06:41 PM   #6
boats742's Avatar
Thanks for the info... Why would it blow breakers if the element was bad? I thought it wouldn't pull any current...
It was 25 degrees when this happened, so maybe I will be lucky and it will still work...
2013 Solera 24S
Charleston, SC
Old 01-29-2014, 08:41 PM   #7
Normally the heater element is a fairly large resistance due to its length. This resistance keeps the current at it's "normal" value. Usually when an element burns out, it "opens up" the electrical circuit and that's that. But once in awhile, when it burns through, one piece of the element can drop down and touch another portion of the element, reclosing the electrical circuit, but now the "effective" element length is much shorter. This means the resistance drops and the current goes up and it trips the breaker. Sometimes you can get this with an incandescent light bulb, too, where it trips the breaker as it burns out. So my guess is your element shorted as it destroyed itself.
Old 01-29-2014, 09:32 PM   #8
bob213's Avatar
Unless designated otherwise, breakers should not be used as on/off switches. You may not be replacing a burned out element, but you stand a very good chance of replacing a worn out breaker. The outside rocker switch is your best bet.
bob213 is offline   Reply With Quote
Old 01-30-2014, 06:50 AM   #9
Wanna Be Camper
SaskCampers's Avatar
Or do as a few other FR members have and install a switch with an indicator light inside the RV in a place where it is easily seen.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 01-30-2014, 07:07 AM   #10
TURBS's Avatar
Such as.
TURBS
oc's buddy
drain, heater, water, water heater
