Old 06-15-2015, 02:58 PM   #11
Since this is a MB Sprinter thread assumed because it's the Solera topic heading. What does Benz recommend?
Old 06-16-2015, 09:48 PM   #12
devilsquid's Avatar
That's what's I was thinking...Mercedes is a whole different world...apparently. I would be interested to see if MB recommends a booster additive or would it void their warranty. With their attitude/guidelines concerning biodiesel I betting the latter rather than the former.
devilsquid is offline   Reply With Quote
Old 06-17-2015, 05:20 AM   #13
Mikegjax's Avatar
From MB operators manual:
Additives for approved service products are
neither required nor permitted. Approved fuel
additives are the exception. Additives can
cause engine damage and must therefore not
be added to the service products.
The use of additives is always the
responsibility of the vehicle operator. The use
of additives may result in the restriction or
loss of your Limited Warranty entitlements.
Do not mix such fuels with diesel fuel and
do not use any special additives. This can
otherwise lead to engine damage. This
does not include flow improver additives.
For further information, see "Flow
improvers".
Flow improvers are fuel additives used to
improve the flow characteristics of diesel
fuels.
The effectiveness of flow improvers cannot be
guaranteed with all fuels. Observe the
manufacturer's recommendations.
Information about approved flow improvers is
available from any authorized Sprinter Dealer.
At outside temperatures below 14 á (“10 Ü),
and if using diesel with less resistance to low
temperatures, add flow improver, basing the
mixing ratio on the outside temperature.
Mix this fuel additive with the diesel in good
time before the flow properties of the diesel
are affected by paraffin separation.
Malfunctions resulting from paraffin
separation can only be rectified by heating
the entire fuel system. Park the vehicle in a
heated garage, for example.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 06-17-2015, 12:47 PM   #14
Pod2Vibe's Avatar
Great post Mike!
Name:	Great Post!.jpg
Pod2Vibe
2015 Solera MBS 24R - Hellwig/Sumo Equipped
TOAD: 2014 Fiat 500 Abarth
(Sold the Vibe 6506)
Pod2Vibe is offline   Reply With Quote
