03-01-2015, 01:42 PM
Chassis Battery
Does anyone know if the converter charges the Chassis battery.
George & Karen
2014 F150 4X4 5.0L 3.55 Axle
Husky Centerline TS 1200lb 4 point WDH
2017 Rockwood Mini Lite 2109S
Palmyra,VA
03-01-2015, 01:51 PM
Yes, it charges coach and chassis.
2014 Solera 24R
USN Retired
03-01-2015, 03:27 PM
Dinghy battery charging
One more battery question. Anyone have a setup to charge their tow behind from the Solera
George & Karen
Palmyra,VA
03-01-2015, 04:21 PM
Why would you need to do that? If it is for brake/tail lights I use magnetic lights that connect to the hitch 7 pin. Just a thought.
2014 Solera 24R
USN Retired
03-01-2015, 04:42 PM
Charging toad
I have the same thing and a Patriot braking system. I am going on over a 4000 mile trip with over nights in between. Some of the stretches may go 7-800 miles with out unhooking. Just worried about the car battery going down. Found a 7' 7 pin to 6 pin coil cable and a toad charge module for the car for less then $100
George & Karen
Palmyra,VA
03-01-2015, 04:57 PM
That sounds good. One word of caution would be to ensure that the charging system can't feed back to the rv. Might damage LEDs. May not be a problem, just a thought.
2014 Solera 24R
USN Retired
03-01-2015, 05:04 PM
Setup prevents feed back and only provides current when the battery needs it.
George & Karen
Palmyra,VA
03-01-2015, 05:11 PM
I like the idea. Could you provide additional info. on your system?
2014 Solera 24R
USN Retired
03-01-2015, 05:17 PM
The cable is a Roadmaster 146-7 and the module is a Toad Charge. Both are available at Amazon.
George & Karen
Palmyra,VA
03-01-2015, 05:27 PM
The module is a BakeBuddy 39332
George & Karen
Palmyra,VA
03-01-2015, 09:19 PM
Charging toad
RVibrake Towed Battery Charger
Check out this one. It looks to have better protection.
George & Karen
Palmyra,VA
03-03-2015, 01:46 PM
Charger
Ordered the Road master cable and the Rvibrake charger. Will let you know how it goes.
George & Karen
Palmyra,VA
03-08-2015, 05:16 PM
Trip distance
Wow, I just checked my trip and realized I under estimated it. It is 6851 Miles.
George & Karen
Palmyra,VA
03-08-2015, 05:25 PM
Now that's a trip!!!
2014 Solera 24R
USN Retired
