Old 09-29-2014, 12:05 AM   #1
Chassis Battery Cutoff
We have a new solera 24s. We stored it for 4 weeks and the house and chassis batteries are dead. I used the shutoff for the house but did not use the one for the chassis under the dash near the gas pedal. Short of a tow truck, i cant find any way to jump-start the coach. Here are my 2 questions: 1) does the under the dash battery cut off work well and how long will chassis battery last if this is used and 2) is there any way, short of a tow truck, to jump-start the coach. Thanks
beaveratc is offline   Reply With Quote
Old 09-29-2014, 12:41 AM   #2
I could be completely wrong, but I would think the under dash cut off simply isolates the chassis battery from the house... but is still active for normal driving conditions. So when you shut off the house batteries, the parasitic draw of the coach was eating away at your chassis battery.
Is there some reason why you can't just jump start it from another vehicle? As another thought... if your house batteries have been on disconnect, they may still have some charge to them.
rana is offline   Reply With Quote
Old 09-29-2014, 12:48 AM   #3
The charge from my 2012 sequoia is not strong enough to supply the cold cranking amps. It took the tow truck 20 minutes of sitting connected to the coach to get it started. He said this is not uncommon for the sprinters.
Old 09-29-2014, 01:04 AM   #4
Glad you got up and running. That's a lot of juice!! In situations like that it's probably a good idea to have the under dash cutoff engaged (off) as well so you're not loosing any charge back into the house.
Have fun!!
Old 09-29-2014, 06:26 AM   #5
Mikegjax's Avatar
From the MB operators manual page 136:
Battery isolating switch
Important safety notes!
Make sure that the key is in position 0 in
the ignition lock and wait at least 20 seconds
before disconnecting or connecting
the battery isolating switch. You could otherwise
damage electrical system components.
You can use the battery isolating switch to
disconnect the power supply to all your vehicle's
consumers. This will prevent uncontrolled
battery discharge caused by off-load current
consumption.
If your vehicle is equipped with an auxiliary
battery in the engine compartment, you will
need to disconnect both batteries. Only then
is the electrical system fully disconnected
from the power supply. Only switch the vehicle to de-energized
using the battery main switch if:
the vehicle is stationary for a lengthy
periodit is absolutely necessary
After the power supply has been activated,
you will need to reset the side windows
(Y page 79).
Switching off the power supply. When you clamp the connector under the
accelerator pedal, make sure that the connector
does not become damaged or dirty.
It may otherwise not be possible to restore
the electrical connection when the parts
are reassembled.
Battery isolating switch in the driver's footwell, on
the right-hand side next to the accelerator pedal
X Remove the key from the ignition lock and
wait for about 20 seconds.
X Press and hold button ; and unplug connector
: in the direction of the arrow from
the earth pin.
X Clamp connector : under the accelerator
pedal so that it cannot make contact with
the earth pin.
All starter battery consumers are disconnected
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 09-29-2014, 08:16 AM   #6
The aux positive connection for the bat is under the hood. Find a suitable ground and you should be able to jump the sprinter.
Old 09-29-2014, 03:11 PM   #7
2012 Solera
JamesR's Avatar
Doesn't shore power charge the chassis battery?
JamesR is offline   Reply With Quote
Old 09-29-2014, 03:21 PM   #8
Mikegjax's Avatar
Yes, but if your not on shore pwr, they all can go dead due to parasite draw.
2014 Solera 24R
USN Retired
Old 09-29-2014, 03:25 PM   #9
I have it at home now but didn't realize the shore power charged the house and the chassis
Old 09-29-2014, 03:30 PM   #10
Mikegjax's Avatar
I only found out about that recently, but it does. Verified through my Scan Gauge II. The Scan Gauge shows the increased charging voltage when the converter starts charging.
2014 Solera 24R
USN Retired
battery
