Forest River Forums
Sunline User Photos
Old 09-12-2011, 03:29 PM   #1
'check engine light' on
On our way to the RV dealer to have the slide seal checked out, the 'check engine light' came on & the engine's power was severely cut/limited...the Solera would go no more than 40 mph. Made for a very long trip.
We were told by the service dept. that it would have to be towed to the nearest Sprinter dealer to be checked.
According to the owner's manual, it's probably something to do with the fuel injection system.
Has anyone had a similar problem?
We have a 2011 Solera that we bought new in June, 2011.
popandgrom is offline   Reply With Quote
Old 09-12-2011, 04:35 PM   #2
Moderator
No one can tell you what may cause a "check engine" light. I am an ASE certified tech, and there are many things that could cause the light to come on. Any Advance store will pull the codes for free, and try and sell you something. Without knowing what code it set, impossible to tell or even guess what it may be.
I know this doesn't help, but I would not tow it to a long distance dealer if there is as an Advance close by.
Auto Zone and others may do the same thing. I have the software and a cable on my laptop so I can scan OBDII codes. Less than $75.00, cheaper than a tow.
Windrider,
Too many toys, not enough time.
2001 F150 SuperCrew
2002 Jeep Wrangler
1978 Cessna 152
2000 Honda 750 Nighthawk
2008 Work and Play 18LT
windrider is offline   Reply With Quote
Old 09-12-2011, 05:40 PM   #3
Boyd's Avatar
Sorry I scared you back there by flashing my "check engine" light.
It goes on automatically whenever my on-board diagnostic (OBD) computer detects possible trouble with my emission control system, including faulty fuel mix, engine performance, electrical circuits, drive train management -- even the sensors themselves.
Chances are good that the underlying problem is something simple and easy to fix. Then again, it could mean big bucks. You just never know. That's why it's so scary.
So while we both wait for your heart rate to return to normal, let me explain what my check engine indicator means, how it works, what to do about it and even a cool way to use it to avoid buying a lemon.
Beyond the oil light
First, a quick history lesson. For decades, cars like me had dashboard indicators that only monitored the basics: fuel level, oil temperature, coolant temperature and whether our generators or alternators were charging.
That all changed in 1981 when federal clean air statutes required catalytic converters on all domestic cars and light trucks to help reduce the level of smog-causing emissions in the atmosphere.
Emission control is a touchy process that involves sophisticated sensors that compare the oxygen entering and leaving my "cat."
Because so many other parts of our engines affect what ultimately comes out of our tailpipes, it takes an OBD system to keep everything performing properly.
In 1996, the feds required U.S. automakers to upgrade to OBD II, a sophisticated system of sensors and actuators that conduct on-the-road diagnostic tests. When the OBD II detects a problem, it logs it as a trouble code in its computer memory. Once retrieved via a diagnostic reader, this code directs the repair technician to the source of the trouble.
While OBD II set the standard for American-built passenger vehicles, many foreign automakers have piggybacked their own proprietary diagnostics onto it. As a result, the check engine lights themselves (and the range of well more than 100 possible problems they can detect) vary considerably.
On some cars, the light simply goes on. On others, it may flash red to indicate an immediate, potentially damaging situation or simply illuminate for non-emergency problems. Still others will display yellow for non-emergency, emissions-related glitches and red for stop-worthy situations.
There are two ways to turn off the check engine light.
  1. A repair technician can do so once repairs have been made.
  2. The OBD II can automatically turn it off when it fails to detect the problem after several diagnostic cycles.
Here's what Ben Moreno, service manager at Southwest Auto in Dallas advises: "If your check engine light comes on and you have no symptoms -- the car's running fine, your temperatures are normal, it's not hard to start -- then schedule to have it looked at.
"If you do have a symptom -- it's hard to start, slow to accelerate, there's black smoke -- let's get it in."
Bright light, big bill
About now, you're probably wondering how far my check engine light might put you in the red, right?
Well, there's good news and bad news.
First, the good news. My OBD II system is so sensitive that in many cases the problem is a simple human error that can be remedied for free.
"Eighty percent of the time, it's nothing more than people forgetting to tighten the gas cap," according to Gary Martin, owner of Martin Motorsports Inc. in Alexandria, Va.
"Or people forget to put their dipstick in tight. The car doesn't run that well because it loses vacuum, it starts to idle funny, the computer senses it and boom -- a code."
A tank of bad gas also can trip a code. So can filling my tank while the engine is running, never a good idea anyway.
Although some dealers and repair shops charge upwards of $75 to hook me up to their diagnostic reader, others will read my OBD II and clear the fault (i.e., turn off the check engine light) at no cost. Just call and ask.
And, all things considered, it's generally cost-effective to repair a minor problem before it becomes a major one.
Now the bad news.
If my trouble code is not due to driver error, Moreno and Martin say that nine times out of 10 it will be traced to an emissions problem, typically either a perforated vacuum hose (repair cost: $100 to $200) or failed O2 sensors ($200 to $600 to replace the pair). Replacing airflow sensors will run in the neighborhood of $400 to $900 depending on the make. A new catalytic converter can run anywhere from $400 to $1,500.
If my code is transmission-related, often a flush-and-fill transmission service ($150 to $200) will solve the problem. But if my tranny is shot, figure on dropping $1,500 to $3,500 for a new one.
Worst case, if my check engine turns out to be a "chuck engine" light, you're looking at anywhere from $2,000 to $8,000. There are antacids in my glove box.
On the bright side, Martin says sometimes the check engine light can actually save you money. That's because some automakers program scheduled maintenance into the ODB II that will trip a code at a specified time or mileage.
"If you're replacing a timing belt and from the readout you know you're going to have to do a water pump soon, why not do it all at the same time?" he says. "You've got to take the same stuff off anyway. Why pay for the same job twice?"
What about the bulb?
With all that responsibility riding on my check engine light, how do you know the light itself isn't burned out?
That's easy. When you turn my key to the "on" position, before starting the engine, all of my warning lights should come on. Once you start my engine, they should all disappear, unless there's a trouble code, of course.
Knowing that procedure can mean the difference between picking a winner and plucking a lemon when purchasing a used car, says Moreno.
"You want to make sure all the indicator lights light up because some people, rather than fix their car, will remove the bulb and sell the car," he says. "You wouldn't have anything there to let you know that a symptom was hiding."
If you want to make extra-sure that the used car you're thinking of buying is in good health, have an auto shop scan its OBD II code log; many OBD II systems keep a record of the car's codes in memory.
Or you can buy your own ODB II handheld code reader from any number of vendors for under $200. But because readers have become increasingly manufacturer specific as automakers pack their OBD II systems with proprietary codes, a nonspecific reader may not tell you much about a proprietary code.
Now let me give you some tips on my satellite navigation system while we drive to the repair shop.
Jay MacDonald is a contributing editor based in Mississippi
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline   Reply With Quote
Old 09-13-2011, 11:59 AM   #4
too fast turbo sled
f1100turbo's Avatar
I bet its just low on anti freeze!
2005 silverado 2500hd pro ride 5th
2011 palomino sabre 32 bhok-6
2012 arctic cat f1100 turbo limited edition sno-pro
Ron and Amy Benhart
2012 nights camped (5)
f1100turbo is offline   Reply With Quote
Old 09-13-2011, 12:01 PM   #5
Try this. Sitting in the seat. Turn the key on and off three times without cranking the engine stopping with the key on. It should display the codes. If that doesn't work try doing it 5 times.
Grand Surveyor GS-280 Pushing a 2500 Mega-Cab CTD!
WOW it's already 2012! Gotta go campin
Old 09-13-2011, 12:49 PM   #6
Danielflading's Avatar
Could be low on headlight fluid also
Seriously the only way to find out is to have the code read and diagnostic done to verify the code and failed part.
Dan, Kelly and Maddy.
Cupid and Kandi the Camp Dogs
Tomball, Texas
2006 Salem LE 29BHSS
2003 Ford Expedition Eddie Baur 5.4 w/ factory tow package
Danielflading is offline   Reply With Quote
Old 09-13-2011, 02:35 PM   #7
too fast turbo sled
f1100turbo's Avatar
Actually I was being serious.
2 trucks that I drive at work if they are low on coolant the check engine light comes on and power is greatly reduced
Ron and Amy Benhart
Old 09-13-2011, 02:48 PM   #8
take it to a pro!
I was also being serious and That is correct, if the engine cvoolent temp sensor detects a temp high enough temp it will also keep the engine from starting, if it is running then limp mode will be engaged and power will be reduced. OBDII has probably close to 1000 codes or more and the only way to be sure of the correct fix is to have it diagnosed and troubleshot by a Tech with a Scan tool. Autozone and others will scan it and sell the part that the code refers too. Many times there can be other problems that are cusing the code. A bad heated O2 code may turn our to be a bad catalytic convertor not a bad O2 sensor. a bad MAF code may be a plugged air filter.
I am a FAA certified aircraft mechanic (airframe and powerplant), I have also been an automotive service writer, and I have two scan tools, one that also hooks up to a PC from OBD-2 Vehicle Explorer Scan Tool Browser If you do not know how to read codes and diagnose errors then take to a certified profesional who can! That is my point.
Tomball, Texas
Old 09-13-2011, 02:54 PM   #9
low on antifreeze would also turn on the Engine Temp light and /or the Temp guage would be getting way up on the high end of the scale.
Reduced power and limp mode could be anything from a bad transmission controller or internal shift solenoid to a bad coil pack on the engine. Diagnostics are in order.
Tomball, Texas
Old 09-13-2011, 03:09 PM   #10
too fast turbo sled
f1100turbo's Avatar
Our trucks never turn the temp light on nor do they run warmer on the gauge the low coolant probe is mounted in the remote mounted coolant tank so normally there isn't enought coolant gone to over heat.
I didn't see if the op said what engine it had in it.
Ron and Amy Benhart
check engine light, fuel injection sysem
» Online Users: 622
113 members and 509 guests
4bnabird, Al Fresco, backin15, Barney1, biggie, biken201, bikendan, Bill m, Bill_C, Cafjackracing, CampinQueen, Canuck_Doug, caper, case1175, cbj, CC Steve, ccyake, COcamper, cpope84, crazn, cstover, cyclepuck, dashonthedash, dasimser, datadr, daw592, dawg82, demoore, DGrissom, DonG, donn, dsgnrdavid47421, dunnnc, dware1962, Ed D, ERRT, etbt1216, fast murray, fchd370, feerobk, Fire Instructor, Fishfireguy, FreedomTracker, frfan, GASPEDDLER, gator man, Go Camping, Goomph, herk7769, hockey11, Iggy, imabmwnut, ironj, jd-ford-hd, JDWeir, jfischer, jimh, jmlocke, Jnied, Jo54, JoeR, JoeyO, jrat, jsutherl, keep camping, KKapa, Kman9936, KRS, kz08h5, lami, Laura June, lcsolutions, LeadPoop, low_flyer, lurch, mikewheel, Mpwelch50, Msaunders, mtofell, N3HCP, Namchief, newtsx3, nightcrawler, OffPavement, pappcam, pbrackney, Penelope, polkatronron, QDog, racerx, Rebel702, ret2006, RichardE, rkswyo, robert elling, Rsgtivr6, sandys, seatosea, Senor, Sockman, softwarejoe, stevengb, tabkld93, Terier, tfedd, tonybab, transamz9, Trempert, troyt, unhcharger25, wayne anthony, Whiteknight, william.migues
Most users ever online was 996, 05-22-2012 at 11:04 AM.
Close [X]
