Old 08-14-2013, 03:51 PM   #1
Check front tire pressure on Solera w/o remove wheel covers
Has anyone found a tire valve stem connection that works great for the front wheels of the Solera, without removing the wheel covers. I notice that camping world sells a 90 degree, that says it is for front wheels. Will this work?
13larry is offline   Reply With Quote
Old 08-14-2013, 05:41 PM   #2
hkreck's Avatar
I check my tires on a regular basis and have never had to take the wheel covers off.
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 08-14-2013, 05:45 PM   #3
This is what I have used in the past 10-150 psi Dual Head Truck/RV Tire Gauge - GEMPLER'S
butch50 is offline   Reply With Quote
Old 08-14-2013, 05:52 PM   #4
hkreck's Avatar
That's what I use to check my also.
Henry & Tena
2013 Solera 24S
The Great Escape
Old 08-14-2013, 06:53 PM   #5
Taylorgso's Avatar
I had the same problem; the valve stem was not long enough to protrude through the wheel cover. The problem was compounded when I tried to install tire pressure monitors on those front wheels. I ordered valve extenders to solve that problem. Straight extenders work on the front wheels!
I still plan to replace the rubber valve stems with metal stems on both front and rear wheels, long enough that I don't need the flex-aire extenders on the rear wheels, either. Haven't gotten around to ordering them yet. Another Solera user posted reference to an outfit that had the proper stems.
Ed (N4RWU) & Becky Taylor
Mistie (Walks 4-down)
Greensboro, NC
Taylorgso is offline   Reply With Quote
Old 08-15-2013, 03:53 PM   #6
I bought straight 1 1/2" extenders from the local auto parts house for a few bucks for a set of four. They work fine, and I have two spares.
tommyb is online now   Reply With Quote
cover, pressure, solera, tire, wheel
