Old 06-21-2013, 10:52 AM   #1
hkreck's Avatar
CO detector
I went outside last night at about 1:30 A.M. and I heard a smoke alarm going off. Turned out to be the CO detector in my Solera. I've had this happen before and I remember some comments about it on the Forum. Any one else have problems with their CO detectors.
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 06-21-2013, 11:43 AM   #2
Taylorgso's Avatar
If it operates like the one I have at home, the detector is designed to sound an alarm when battery is low. My understanding is that the detectors are wired directly to battery, not through the batt. disconnect. I have no idea at what charge level they sound, but you may want to check batteries (charge & electrolyte level) next time you hear it go off.
If it's going off and battery level is good, I'd presume you may have a bad detector.
Ed (N4RWU) & Becky Taylor
Mistie (Walks 4-down)
Greensboro, NC
Taylorgso is offline   Reply With Quote
Old 06-21-2013, 12:14 PM   #3
papap's Avatar
Switch
I ended up putting mine on a switch. Only turn it on when we head out to go camping.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 06-21-2013, 12:40 PM   #4
hkreck's Avatar
Ed
Thanks for the idea but I've noticed that it only does it when I have it plugged in. right now it's plugged into and shore line from my garage. I haven't noticed it go off when on battery alone?
Henry & Tena
2013 Solera 24S
The Great Escape
Old 06-21-2013, 02:58 PM   #5
Taylorgso's Avatar
Ed
Now that IS weird! It does sound like you may have a faulty detector. Should be in warranty.
Greensboro, NC
Old 06-21-2013, 04:11 PM   #6
hkreck's Avatar
I may have to explore that option.
Henry & Tena
2013 Solera 24S
The Great Escape
Old 06-21-2013, 04:24 PM   #7
kingwood390bh's Avatar
I had the same problem. Even with new batteries it chirped. I found one at Lowes for $19. They used to be $50
kingwood390bh is offline   Reply With Quote
Old 06-21-2013, 04:45 PM   #8
trudinator's Avatar
Ours did the same thing. It was defective. The factory had a bad bunch of them, but they should have run through those by now.
2012 Rockwood 8293RKSS
trudinator is offline   Reply With Quote
Old 06-22-2013, 05:46 PM   #9
hkreck's Avatar
trudinator
What did you have to do to get it replaced?
Henry & Tena
2013 Solera 24S
The Great Escape
Old 06-23-2013, 05:31 PM   #10
Mine goes off too when on shore power and when 90 plus degrees outside.
2013 Solera
Antiochrich is offline   Reply With Quote
