Old 12-03-2012, 09:35 AM   #1
CO light
Is it supposed to be flashing or steady green?
DebbieMH is offline   Reply With Quote
Old 12-03-2012, 09:43 AM   #2
bikendan's Avatar
from what i remember, steady green.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 12-03-2012, 10:11 AM   #3
Any idea what flashing means?
Old 12-03-2012, 10:37 AM   #4
MotocrossCamper's Avatar
On ours blinking is normal operation. I would say its about a 5 second delay between blinks.
Until the day I die I will tell people to buy one with a digital read out. Especially in an RV. Takes out any of the guess work. I can look at mine and see when levels are increasing, it allows me to pop open a window and circulate some fresh air if need be.
MotocrossCamper is offline   Reply With Quote
Old 12-03-2012, 10:41 AM   #5
Dave_Monica's Avatar
The flashing is probably something that the manufacturer's have switched to. It would reduce the drain on the 12V system when not on shorepower.
Dave
Old 12-03-2012, 11:58 AM   #6
2012 Solera
On my 2012 Solera "S" the green light flashes when I first turn on the 12 Volt stairwell switch - for quite a while (minutes - maybe 5+ minutes). The propane seems to work normally during this period. The light eventually goes steady green.
JLeising is online now   Reply With Quote
Old 12-03-2012, 12:04 PM   #7
My post was in reference to the CO detector. The LP detector is completely different.
Old 12-03-2012, 01:42 PM   #8
2012 Solera
Believe it is a combination CO and propane detector on the Solera.
Old 12-03-2012, 01:50 PM   #9
My bad, I thought they were still separate. You would think for safety they would keep them apart so they could be mounted and the proper height.
Old 12-03-2012, 02:17 PM   #10
VinceU's Avatar
I've had three or four Carbon Monoxide detectors over the years and they've always flashed red and steady red with alarm horn when gone off. I had to change mine this Georgetown after a few months it was giving off a expired code. The factory changed for free. My present one is made by Costar. The red flash simply means its checking the atomsphere.
