Old 04-30-2013, 11:26 AM   #21
Thank-you for your quick response! Can you answer another question for me? I prefer a softer mattress than what's in the RV. Is there a mattress option for the Solera s model?
Bootsie63 is offline   Reply With Quote
Old 04-30-2013, 11:31 AM   #22
Commercial Member
Unfortunately not. However, you can custom order just about any foam mattress. Innerspring mattresses are limited due to the metal frame. Foam, can be cut to any shape/size. You could also add a memory foam topper or equivalent.
If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
Subscribe for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Sales-Service-Parts https://dynamaxcorp.com/contact-us
Old 04-30-2013, 12:38 PM   #23
Sandiegodoug's Avatar
I topped mine with a full size 4 inch ultra foam from wallyworld on line and it made the bed very comfy for around a hundred bucks
I take a lot of stuff with me when I camp and the compeditors were useless for our needs
We have the s model
Sandiegodoug is offline   Reply With Quote
Old 04-30-2013, 01:21 PM   #24
We have the s model
I too topped mine with a foam top (double bed size) and it is also quite comfy. I have also found that with the foam topper, it is easier to tuck in the sheets. I also use the elastic clips to hold the bottom sheet in place (two elastic clips work wonders). I use just regular Queen size sheets, and haven't spent the money to buy special sheets. I have a S model with the corner bed. The corner bed is a bit of a pain to climb over the other person to get up, but otherwise, it is fine. (I'm the one who gets to sleep closest to the window, hence, I'm the one that has to climb over!)
DebbieMH is offline   Reply With Quote
Old 04-30-2013, 07:53 PM   #25
hkreck's Avatar
Try it with two (small dogs) in the bed also. Still not sure how that happened?
Henry & Tena
hkreck is offline   Reply With Quote
Old 05-02-2013, 10:29 PM   #26
I'll check into that! Thank-you for your help!
Old 05-03-2013, 05:46 AM   #27
Your pups are so cute, they belong on the bed - I can understand how that happened!
Old 05-03-2013, 05:39 PM   #28
hkreck's Avatar
Oh if you only knew them, The little one is the devil in disguise.
Henry & Tena
