Old 12-18-2013, 06:49 AM   #1
boats742's Avatar
Compressed Air Enough to Winterize?
Is compressed air enough to winterize the RV water lines or do I need to put antifreeze in the water lines after the blow through?
I know I need antifreeze in the drains. Thanks!
2013 Solera 24S
Charleston, SC
boats742 is offline   Reply With Quote
Old 12-18-2013, 06:51 AM   #2
TURBS's Avatar
Yes blowing out all lines with compressed air is fine.
Dont forget....
Remove water filter.
Drain wh tank and bypass.
Low point drains.
All shower heads.
Turbs
Sent from my SCH-R530U using Tapatalk
Old 12-18-2013, 07:09 AM   #3
avolnek's Avatar
Dont forget....
Low point drains.
All shower heads.
Turbs
X2
I only use air in my water lines and a gallon of antifreeze through my drains....
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
Old 12-18-2013, 07:11 AM   #4
TURBS's Avatar
Also make sure you regulate air pressure.
25 to 30 psi will be fine.
One other thing I should mention is some newer units have a little water pump strainer that should be taken off drained and cleaned.
Turbs
Old 12-18-2013, 07:20 AM   #5
JoeR's Avatar
And don't forget the toilet lines....
2008 Toy Tundra DC 5.7L Bagged w/LTs
Hensley Arrow
2012 Windjammer 3001W, Atriumed
JoeR is offline   Reply With Quote
Old 12-18-2013, 07:31 AM   #6
I tend to be over protective and do both. Better safe than sorry
Rockwood 8282 WS
2012 F-250 6.2
farfetched is offline   Reply With Quote
Old 12-18-2013, 07:33 AM   #7
avolnek's Avatar
On my father's camper we do both.. Once the anti freeze is in then we re do the air step and blow it all back out, but this way he can guarantee himself he got all the water out...
Old 12-18-2013, 08:02 AM   #8
TURBS's Avatar
Me to
Old 12-18-2013, 08:19 AM   #9
2012 Solera 24S
And don't forget the low point drains, outside hose, and the tank flush.
I also do both, it gets down to -10 around here and I don't like to take the chance.
Nats is offline   Reply With Quote
Old 12-18-2013, 08:42 AM   #10
Fulltime family RVer
Too true! I had to have a water valve replaced on our toilet because it cracked because I didn't blow out the lines to that toilet. RV guy said they sell a lot of them come spring.
winter, winterize
