Old 07-27-2013, 11:48 AM   #1
brania
brania's Avatar
Converter blown fuses
Hello
My batteries will not charge from generator. I have located converter and found 2 blown fuses. I replaced them and they blew again. Has anyone experienced this and is there a solution? ( other than a new converter)
Andy. 2011 24s
brania is offline   Reply With Quote
Old 07-27-2013, 12:13 PM   #2
Herk7769's Avatar
Most likely your batteries are installed backwards.
Check and verify your wiring is correct.
The 2 blown fuses are the reverse current protection fuses.
HAM CALLSIGN - KC3FFW
Old 07-30-2013, 10:04 AM   #3
Any update on this. Sounds serious to have batteries installed backward. Wouldn't that spark like crazy when connecting the terminals backward?
2012WhiteSolera is offline   Reply With Quote
Old 07-30-2013, 10:56 AM   #4
TURBS's Avatar
Short answer is no.
If you rember back in the day many ag tractors were positve ground
Old 07-30-2013, 06:22 PM   #5
Herk7769's Avatar
In fact, many things (like your lights) will work just fine. Things like the fridge and the furnace will not. Water pump will run backwards though. LEDs on your monitor won't work.
Converter fuse blow to protect the converter; not necessarily the camper.
