Old 09-22-2013, 10:49 PM   #11
2012 Solera
As noted above, in my 2012 Solera "S" I believe the converter is mounted under the refrigerator and is combined with the fuse box.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 09-22-2013, 11:06 PM   #12
On mine the furnace is under the refrigerator. Under the drawer below the oven (left of the refrigerator) is the IDP 120 vac/12vdc distirbution panel with fuses and circuit breakers. It is very small. I cant believe this is the converter!
I changed a converter in a travel trailer and it was much bigger than this IOTA thing.
Where the hell is the converter???!!!
2011 Solera 235S
Freightliner Badge
cousin01 is offline   Reply With Quote
Old 09-22-2013, 11:34 PM   #13
2012 Solera
You are probably right - I'm working from memory. Furnace under fridge. Combo converter - distribution center - fuse box under drawer below oven.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 09-23-2013, 12:15 AM   #14
No. Under the oven is only the power distribution center.The converter should be about the size of a shoe box and thie IOTA IDP-30 is not that big.
Still looking!
2011 Solera 235S
Freightliner Badge
Old 09-23-2013, 12:30 AM   #15
2012 Solera
Suspect 2012 is different from 2011. Let us know what you find.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 09-23-2013, 08:24 AM   #16
GM
bclemens's Avatar
Check under the bed. We remote mount the convertor.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 09-23-2013, 11:32 AM   #17
2012 Solera
Cousin01, Brania - sorry for the earlier misinformation. Brian - thanks again for your help. Good to correct my misperception about the converter location.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 09-26-2013, 07:10 PM   #18
Taylorgso's Avatar
What about on a 2013 24M?
Ed (N4RWU) & Becky Taylor
Mistie (Walks 4-down)
Greensboro, NC
Taylorgso is offline   Reply With Quote
Old 09-27-2013, 08:21 AM   #19
GM
bclemens's Avatar
Under the bed? Can I be right twice? drum roll?
The board under the mattress lifts up from the middle exposing a big area.
Old 10-05-2013, 07:36 PM   #20
Send a message via Skype™ to Pedrodasdas
I'm dropping in late but here is the location of the converter for a 2011.
Empty your cargo area and unscrew the white panel on the right (fridge side)
In fact you have to unscrew also the bottom panel to remove the right one.
You will instantly see the converter.
All the dealers around Montreal wanted $400 for that part and had to order it.
I found the same one, brand new, on EBay, for $105 received it 2 days after.
Pierrôt and Sylvie D'Astous, Solera 2011
Canada in summer, FL-TX-LO-NM-AZ in winter !
Nights camped in: 2014-96, 2015-139, 2016-89
Pedrodasdas is offline   Reply With Quote
